the default detection current in vesc-tool is now 20amps??
or were you increasing the i value because detection was failing at lower current levels?
It automatically puts 20a lol
Shouldn’t it be only 5a?
for the motor sizes we use, that sounds more reasonable to me. but what do i know?
You should use the wizard, since there you can select a motor size and then the detections amps are matched to the approximate stator size.
Dude, I’ve done that, I did the detection and the resistance is absurd.
Then there is a HW issue.
So what am I supposed to do now, I asked for help lol
It needs to be fixed by some one doing VESC repairs.
You could take the PCB out of the housing and inspect it visually.
Sometimes it is possible to see physical damage.
No damage to be seen, did I void warranty lol
You can PM me and on Monday I will forward you to customer support.
Check your drv chip. I am almost sure it is blown.
I had the same thing on my trampa vescs
DRV dsnt always physically show its done. Since your 5V rail is fine, its at least not dead. My bet are on borked DRV, coldsolder joint somewhere near it or a FET went byebye
Wait ur right, I was in @pjotr47 thread from a while back and it should be there
This looks fine, you can see the gold plating.
Either something is wrong with the DRV or something on the voltage divider or the shunt amplifiers.
Could also be a Mosfet.
Lol I’m with @Trampa on this one, hardware vendor cannot be held accountable for users installing untested firmware.
Its like me expecting Del to have tested my Windows pre-installed for running Ubuntu.
Can’t say it’s up to the software guys to make sure it works for all hardware when talking VESC tool then say it’s up to the hardware guys to make sure all software works LOL
