Thanks man! Loving it. Ive been inspecting it before and during rides since as well. So far no issues with anything coming loose. Everything has loctite as well.
I’ve been using red n tacky before rides. Do you guys just lube up the whole spur gear or put a dab on the motor gear? I also was considering being some with me and adding it half way through say a 30 mile ride. Still getting to know these and what needs they have but man they run so smooth and I was surprised they’re not nearly as loud as I thought they’d be.
Stats from the the first real ride. Super fun ride through a very hilly area. Zero issues powering up them like they were flat. I am loving having a high voltage setup.
may i ask you smthg.
ive seen guys mounting the back collars of the 3link road side and you have it board side (think this is correct)
do you ever tried if mounting it roadside makes a big diff.? as far as i understand it will change the angle making it less stable in the back can you confirm this?
KR and keep save!!!
As you increase the angle of the rods you increase your turning. So you basically have three positions with the rods mounted with the collar boardside and three positions of angle with the collar mounted on the roadside. Roadside will have a steeper angle and thus more steer when you have the truck facing this direction. Lots of ability to tune these.
@dskate Yo Dallas, can you do me a favor and snap a quick video that shows what the flex is like for your odashi? Some nice gentle bouncing with a normal stance and in the middle of the deck would be rad.
Also, what ply and deck construction did you go with?
Thanks man. Love this build. And unfortunately now I feel like I need one.
