On another note I hope I someday find the crazy customer who wants a Trampa 100/250 and a matching 22S2P pack. Now that would be an epic reason to get the board widened.
I thought I was watching the thread but somehow missed messages.
Did you settle on your final design yet?
FWIW my pipe dream plans for an XR build were entailing making the controller box full length and “somehow” make the cable connecting work:
- You don’t need a battery connector at all, you can just do a fixed cable like on the Pint
- For motor phases I thought to use MT60 outside the box and just hide it in the rail. Seal it with teflon tape or shrink tube with glue or something
- For motor sensors maybe an external grade connector could be found that would fit on the cables inside the rail too
- No clue about footpad sensors but something could surely be hacked together
Note I am thinking with decent to good waterproofing in mind… without that you can just do whatever
The point is the connectors take way too much space that can be used for batteries
But then again if there will be a 19S2P 21700 battery box, maybe I’d just put the last two cells in the controller box to get to 20S and call it…
But I won’t be doing an XR for some time yet…
that’s exactly what im trying to do with an XR at the moment. Mt60 for the phase cables and Julet Mini plug for the sensor cables.
Problem is that im not that good at CAD. I would need a cad model of the OW with rails or at least the back enclosure so i can modify it.
I also would like to remove the front handle and replace it will a side strap so the enclosure can be even bigger.
This would be a good place to start. Sadly it cant even fit a bms.
Look no further my friend, I already have done more than half this!
Speaking of, I got a notification that I was refunded for this 20S smart BMS but I guess it changed it’s mind. It will be really awesome to use it with METR… The OW that everyone wants!
What 20s bms are you going to use?
This is the only smart bms I found that could reasonably fit. Its flat enough that you could still put one layer of cells above it. But I would also accept “only” having a 20s2p in the battery compartment and the bms and controller in the front.
I Also would like to 3d print the enclosure with a metal plate at the top (and maybe bottom) similar to the case I posted on thingiverse.
https://www.amazon.com/gp/product/B083QY5QQ1/ref=ppx_yo_dt_b_asin_title_o02_s00?ie=UTF8&th=1
I found the 30A version here with the dimensions listed. I found the source on ali but no dimensions listed for the 30A for some reason.
I will release after I get it and refine the model
amzn link Claimed 30A Size: Approximately. 170 x 60 x 12 mm / 6.7 x 2.4 x 0.5 in
other 20 non smart BMS on amazon: Size: 120* 60* 9mm.
it nearly fits right in that XR stock case
That looks great. Even if it doesn’t fit in the back it would still save a lot of space.
I recently repaired and testet a OW V1 with an increased battery (14s3p). It has a smart bms so I could look at the power it’s actually drawing. It only uses 500-600W when accelerating hard the highest we got was 900W peak. So the battery of a DIY OW really doesn’t need to be very powerful. At max 1000W continuous 1500W burst or something like that. That’s still probably to much for the hub for a longer time.
well you are skipping over where you turn the setting wayy up on the DIY wheel. I don’t think a weak battery would like my 100A batt 150A max ABS…
I still think a 24S A123 pack is nearly the perfect choice except in terms of range/ not having a split pack, although a BMS is optional with a123 cells as long as you check em every 20 rides maybe.
Im 100% sure you will never even come close to 100A batt on 20s thats 7200W.
That would be completely absurd on a onewheel. Its just not the kind of vehicle that can actually use that much power. Even if you somehow draw that much you would burn the hub very quick.
My estimate is that you pull no more than 10-15A bat just riding around normally and maybe 40A bat for very short on accelerations.
you have clearly never hit a pinecone or root while going up a slope.
Okay that’s interesting. I never saw a metr log from a OW. But my guess is still that it wont be 7kw. When going uphill with pinecones my guess is that you go fairly slow so its only the motor current that will be very high not the battery current. But im happy to be wrong and see 7kw OWs
The question still is do you need to build your battery to that spec since the time is so short. OW pints work very well with just a 15s 1p of 18650s
I dont even know if its a good idea to have the power that high. It could maybe make wheelspin more of a problem.
hmm do I keep my making my 'build thread" here a place to put anything interesting involving OW modding?? not sure.
Just watched those yesterday. Very cool and interesting for me, I’m not surprised by anything except their tire choices
So, I’d be interested in yours as well.
picking back up
bang bumper and box dim still messed up slightly
redo the box cutout while im at it
19S test… still want to extend the hub mounting and solve the bumper mounting issues and widen the board a bit.
Directions
I guess I could have used a hot air gun to melt those strands down at risk of messing up. Needs changes to be good enough without reinforcement. Although thin wall will help me find the weakness.
Thinking about more dramatic mods to existing common parts to increase enclosure space.
First one I already tried which is grind down the handle on the bang bumper to make the front case as long as the rear case, although if you were really going crazy to fit cells you would run battery side bumpers both sides.
I was thinking you could also cut the entire end off and move it out, but I don’t like that as much as cutting it down the middle and widening because it accomplishes the same goal but keeping nose and tail clearance. Widening involving motor mounting hardware so not as easy/cheap. Footpads would need clamps instead of bolts on the side closer to the wheel because rails not being underneath.
These mods avoid raising the footpad higher which is also a way to go, I was thinking about ways besides that.
Also related to these goals I would like a module that fits into bang bumper light cavity with LEDs either battery or internally powered with vesc controlling color and brake indication, I guess a version fit the XR bumper also.
I think Im gonna say fuckit and buy the Satiator
Ok so I posted only this one picture of the battery packs I made for the 24S1P 26650 M1b lifepo4.
While those series connections were unable to be shorted they were possibly more prone to breaking.
This keeps them a nicer shape. Excuse the non taped packs I need to figure out balance wires again to find any possible improvements.
Shorter series connections because the output sides of the 4S packs face each other vs away. Again this is a trade off between accidental shorts and quality of connections and stuff.
