[US] Tomiboi yard sale round 2!!!
The only smaller enclosure I have is a single stack. It wouldn’t be deep enough tho.
Yeah I was hanging out for that double stack forever but 110 bucks shipping is a bit hard to justify.
Ouch! That sucks! Shipping to the other side of the planet is expensive.
Ah I’m super bummed, I really want to build on this deck but the enclosure won’t give me the clearance I’d like :frowning:
odds are eboosted has something that will work
If it helps with the clearance, we have 16mm risers with integrated tail light you could use with this deck.
What’s the set-up going to be?
You might try using a thick gasket on a single stack.
Ive got a brother in SD if you’re interested in selling the enclosure cheap :stuck_out_tongue_winking_eye:
Another way to go if you want clearance is to bite the bullet and buy a 12s4p 21700 pack with the single-stack enclosure. You need a small BMS and any ESC other than a Ubox to make it happen.
Buying another battery might suck it, but this could be the best solution, if you want to do a build with clearance.
@tomiboi got any b stock honeybadgers by any chance?
Not at the moment.
