No notification here
BEHOLD
the monstrosity
it is Incredibly Large, especially compared to the old setup
yet somehow, even with 240mm hangers. with a centerset front, it doesn’t even come close to wheelbite (with the lean stopper installed)
funnily enough, the deck dips under the center of the tire when turning, so you’re far more likely to get footbite than wheelbite ![]()
Looks nuts ha - which wheels are you using on this? Haven’t picked up a set yet and looks like yours have the perfect backspacing for these hubs.
It does look nuts! I can’t tell whether I love it or hate it, so far a bit of both!
These wheels are DWT 705-179. The hubs are designed for wheels with 2” backspacing like these, but you’re free to space out drivetrain components and use increased backspacing. Doing so would put less stress on the bearings, it’s just harder to mount stuff to the hub with the wheel in the way.
Thanks! Looks like these are 5" (center) and I’m curious on how you decided to go for that size - when I was looking at wheels 6" (center) seemed to be the most common with the most tires avail so I was thinking I’d go for that.
6” with 2” backspacing is a little harder to find in stock. I ordered the 705-34 originally, but the shop I ordered from called and said they were out of stock. They told me they usually use the 5” on the particular tires I got anyway. Hopefully I can still get a good contact patch with the narrower wheel, but I can always grab different wheels if not
Ah you’re talking about the width right? I was actually asking about the center diameter in my post, should have specified. Still good info tho - was still researching / thinking through width questions as well.
Oh I did miss that! Yes, 5” inner diameter on these. 6” might be more popular, but I don’t see many 10” tires with a 6” inner diameter, and I definitely don’t want to size the tire up any further!
Cool - I figured it might have to do with keeping a more sensible size for racing slick tires.
I’m more looking to explore turf/treaded tires for even goofier monster truck looking setups ha.
The main problem I’m picturing in my head with my idea is that on wider 6" center kart wheels with two inch backspacing and big tires it seems like a lot of stress on the axle right at the bearing for off-road and might defeat that purpose - might need to keep the wheels narrower?
That gear looks like 10 inches ![]()
I want to see it moving
For serious off roading, stresses will certainly be higher than on the street. I’d say increase the backspacing or decrease the wheel width.
Do your trucks allow you to mount the motors very far inward on the hanger, near the baseplate? If so, you could run more backspacing and use printed or laser cut spacer(s) on the back of the hub to mount your pulley or gears outside the wheel, but around the hanger instead of on the axle. If you have the clearance, that’s by far the best option for bearing longevity.
Oh, and also using 4 bearings in the hub if you have the axle space ![]()
That’s a good idea - I just got a 3D printer and have been fiddling around enough to make some spacers I think, especially if I find an existing file to just modify.
Although, your setup has got me thinking I may also want to try a 5" wheelset with rain tread kart tires.
Which raised a question about hardware since the 5" wheels I was looking at were metric pattern. So If I understand correctly the hubs have threaded M8 holes for the metric pattern. What’s the depth of M8 stud needed? Also would it be a problem to use flanged M8 bolts instead of studs? Don’t have any experience with kart hardware.
The intended hardware is a 35mm wheel stud. I think if you just use a washer under a flange bolt, to avoid marring the aluminum wheel surface, it would be fine.
Thanks - my hope is that the flange bolt + blue loctite would be a workable solution so I wouldn’t have to take studs out of the hub to change on a different pattern wheelset.
I don’t have experience with kart specific hardware either, but I’ve read that the convention is to use red loctite on studs and crimp thread nuts, which is pretty heavy duty threadlocking so I assume it’s justified. Be careful with surface prep and use plenty of the blue!
And a lot of torque on the bolts! It’s the friction of the bolt head and the rim keeping everything together and centered. I discovered this with vantablack
I need less time on the internet because to me it looks like a brazilian woman.
i want whatever this guy’s on
Got mine yesterday in the mail. Received my shipping notification email that they’re on their way today haha.
I figured out what happened I have to manually send those so when I shipped I forgot do that lol
