SOLD
107 superflys (reflys?)
maybe 100mi max on them, no chunking and were amazing! super buttery and smoothe, i just tried pnuemis and couldnt come back.
$25
dickyho 36T aluminum wheel pulleys 15mm wide, some shaving of the hanger required when using on a TB hanger
$40
janux original mounts. used but in great working condition. These are “medium” length based on his available options. I may have the motor pulley covers as well. Comes with 3 out of 4 idler bearings. You will have to source 1 more bearing set (smaller vs standard) depending on belts u decide to use.
$80 for shipping yes… Plus cost of wheels or whatever other parts u might want… Buy i only weighed the wheels so shipping cost would increase with more parts…
i dont BUT if you have the trucks in hand…and slide a skate bearing on the shaft…if the bearing is bigger than the hanger then they will fit. A bearing can seat perfectly inside the pulley if someone wants… or you can just reverse engineer with the info i just provided to come to an answer
