Selling these parts as I’m moving on to other projects and they just don’t see the light of day as often as they should. I’m in the bay area and will only be shipping to the continental US. Everything in the listing was used on the same one board with at I would assume around 100 miles on it at most. All parts used as part of a weekender board, never ridden hard or abused. I will only be responding to replies and questions from the posted date until March 5th as after that, I will be unable to respond to replies or queries for about a month. After then, I will return to taking orders if any items are left and answering any questions/concerns if they arise.
-The buyer will pay for S&H fee
-I will cover the PayPal G&S fee
-I will not be handling returns, everything is bought as is.
Flipsky FSESC 4.12, Battery Display, and TB Remote
Description: I have a Flipsky FSESC 4.12 with a battery display and Torque Boards nano remote all attached together. I hesitate to sell them separately as The battery display has been soldered to the ESC’s input wires so I did not see a point in removing it and as for the remote, It has been hot glued (which can be removed) to the ESC “servo” cable and as such, I did not remove them as of now. Everything here is in good condition and I would like to see them go together.
$85 (USD) OBO:
10S5P Battery, Charger, and Extra 3D Printed Loop Key Slot
Description: This “lot” comes with a Pitbull Electric Skateboards 10S5P lithium pack (Panasonic ncr18650bd 15,900mAH, XT60), its charger, and just for fun, a 3d printed loop key slot (XT90)for your enclosure. Again, I’d like to keep everything together as they’re all in good condition and go with each other.
$250 (USD) OBO:
Torque Boards Single Motor Mount Assembly
Description: Motor mount comes with clamps, bolts, and screws. Everything you’ll need. Keep in mind, one of the clamp to mount screws has been replaced with a replacement which is a tad shorter but still does the job well. It is in good serving condition but definitely has some cosmetic scratches on the exterior of the mount.
$45 (USD) OBO:
Torque Boards 6374 190KV
Description: Torque Boards motor is definitely a solid part that’s never failed me in its time however it has seen some wear. It a powerful motor but it’s important to keep in mind the sensor cable insulation has a slight tear in it. The sensor cables still fully functional and it’s still all working. The exterior just have some scratches as to be expected with its mileage but it’s still a strong runner.
$85 (USD) OBO:
Caliber II Trucks and Hardware
Description: An awesome pair of trucks that-- look slick even with the mileage. They’ve got wear such as indents from the motor mount but besides that, still flawless trucks with all the hardware included.
$35 (USD) OBO:
Torque Boards 36:16 Pulley and Belt Combo
Description: The combo set from Torque Boards comes with a wheel and motor-mounted pullies, two 12mm belts, and all the necessary hardware. Parts have normal wear but still work as intended and in good mechanical shape. The two belts are next to new (one lightly used one brand new) and still have a lot in them.
$25 (USD) OBO:
2 Headlights and 2 Backlights
Description: These 2 headlights and 2 backlights with the included mounts work on most trucks including Caliber IIs (just make sure you have long enough hardware)and boy are they bright. They charge via normal micro USB and I would like to see these all go together as it would brighten someone’s day :).
$70 (USD) OBO:
Custom CNC Truck Top Washers and Spacers
Description: Not too much to say on these, I had the washers custom made and they’ve got a few knicks but still shiny and eye-catching. As for the spacers, they’re what you’d expect and 1/4 inch thick.
$30 (USD) OBO:
Build Kit Boards 97mm Wheels
Description: Great wheels that have lasted me as long as I can remember and still have hundreds of miles on them to go. The only visible wear is on the wheel that was connected to the motor where the tread is lowered due to the power as expected.
$30 (USD) OBO:
PLEASE DO NOT HESITATE TO ASK ANY QUESTIONS
