Yeah Whatever man
Sexy af
I do But it’s ok
Looks beautiful! Which wheel hubs are those? Janux?
What vesc are you using? Would you be able to share your settings?
Beeeeasty. Love it!
oohhh they’re 3d printed?? @ThermalChild how are they holding up?? Did you get them done somewhere or print yourself?
They’re beautifully machined aluminum not 3D printed. They’re not Janux hubs. Also they’re not being made anymore
aoohhhhhhhh
Those files linked by @esk8jpn are the source files that they were machined from?
@ThermalChild
Really? It is still listed on his website.
@donta42
@mishrasubhransu runs long distances with a 3D printed hub and Aliexpress’s pneumatic tires.
It’s not really distance that matters. It’s speed, vibration, the amount of road debris, heat and lean and the cumulative stress that puts in a wheel. Those are the criteria that define the viability of a wheel.
If anyone has used adapters they’re willing to let me play with or sell, I’d be most appreciative
in my experience the eLofty / @nathen kegel adapters are not the same as OEM kegels… your mileage may vary…
and just a thought, to really tighten up the drive can, clean all your threads, add locktite, assemble and then 5-10 quick hard accelerations in reverse should do the trick… however your other can cap will probably come lose in the process… jajajajaja
rinse and repeat with the other drive in forward after the first can has cured…
your welcome and I accept paypal
Andrew are you experiencing any cooling issues with the tbdd and pneumies?
Andrew is anorexic so it wont matter
Really wasn’t it the opposite?
changes every week
is anyone with these hubs? how are they with lofty 58kv???
is bergmeister wheels with printed hub for DD good ??
thx
I’ve acquired the 58kv DD - looking for available wheels and adaptor now.
