Where can I currently source berg hubs? - 3D printed hubs are fine, maybe even preferable
Timo (haggyboard) is currently AFK while he is transitioning to a new production base in Europe, so those are off the table for the time being. If you want bergs, keep an eye on the used market and be ready to leap on any that come up. They are moving pretty quick these days.
@mishrasubhransu is your guy for this. He was working on a hub design that I believe he put a couple thousand km’s on. Seriously impressive stuff.
This is true, however, I have noticed it’s almost always M4x8mm bolts work the best to mount most motors
Cheers man, I’m fairly light so some 3d printed hubs would probably do me fine. Will get in touch with that guy, I don’t have a printer, so hopefully he (or someone here) can do me a solid
There are lots of websites that will link you up to someone with a 3d printer for $ if you cant find anyone on here.
I would hop on over to one of the numerous 3d printing topics on here and see if there are any folks in the UK who could help you out. I’m sure if you offered to buy them a roll of filament and have it shipped to their address, someone would be more than willing
yeah, uk would be better. LD shipping is always unwanted. dont suppose you know if these are the files?
Those look promising
I have never used them, so I would wait to see if @mishrasubhransu will chime in with his wisdom on this topic
just found the page here, seems i can get kegal prints, wtf!?!? 1000% more interested as I can swap out with the new BN’s GD kegal set.
Now you’re thinking with portals
Geo_E_FTW™
Use low Kv motors if doing that.
Like 130Kv instead of 190Kv, et cetera
That board seems super sketch. Top mount pneumatics will be weird like that, plus the deck is not exactly made with obstacles in mind. Mountainboards self balance and handle those roads much better, but still expect to do like 15km/hr on anything but wheelbarrow wheels
Just set duty cycle current limit start at 85% and don’t worry about anything else. Also traction control is really nice to have and won’t let motor rpm’s pass each other by too much
5p 40T configuration can pull 125A continuous without a sweat. Are you sure you want to limit yourself to a non-configurable blackbox esc? Scout this forum and look for something that can to 100A/side as a minimum. Dv6 from makerx and trampa’s vesc 6 are 2 solid candidates
M4x8mm with shallow socket cap is what you want
Edit: make sure they are with 3mm allen key hole. 2.5mm will strip immediately
Why is aliexpress website in german every time i open it and how do i fix this
Time to learn german i guess.
Go to account in the bottom right, the second last option are the settings where you can change the language.
Have no idea, half of the time mine opens into French
Log in. Easiest and best way to fix it. All the other ways are janky and don’t work half the time. You will learn the German words for logging in, username, and password
Worked! It’s the 3 dot menu in the top corner then “konto” for me though. Thanks
How hard is it to remove green loctite?
I have some bearings with weird tolerances for bergs hubs and i’m thinking to glue them in there to stop them rattling, but as all bearings are basically disposable, i want to know i can pull them out as well
