Hey,
I kind of lost the switch that comes with the unity, i have a momentary switch laying around and i’m trying to figure out the wiring for the unity.
I found this schematic :
What are the led1- and led2- used for ? Can i leave one out ?
I only have 2 wires for the led on my switch, and not sure wich one i should wire to wich pin. The + is kinda obvious, but i’m not sure about wich - i should use.
MOM pins.
If you bridge those you turn it on. Nothing else needed.
The LED pins control fancy LEDs inside the original switch. One for each colour I’d guess (they share the same supply pin, LED+). I have no clue what function any of them have unfortunatly. Try and u shall find out
I’m in France, i’m affraid shipping from the US might be a bit overkill for a switch But since you have a few of them on hand, are the 5 pins wired on the original switch ?
Im extending the wires on my switch and I labelled one of the white wires before cutting them. Label has fell off now so no obvious way of finding out which wire belongs to which.
Can anyone help? Can the white wires be mixed? @Deodand
