I just had a weird thing happen. my board when given throttle locked on full throttle until i turned the unity off I got it on vesc tool to inspect the PPM signal… and then the problem went away.
I have a board with a unity and hoyt remote and metr
unity fw 23.46
have a suspect remote I was testing.
then these steps.
pair suspect remote.
use vesc-tool desktop to turn ppm control mode to off.
use realtime app data and mapping page to test suspect remote.
finish testing.
pair original remote.
go to ride board. realize didn’t set ppm control mode back.
use metr expert mode to set PPM control type back to current no reverse with brake.
fwd on remote is unresponsive. hitting reverse board takes off and stays going into the wall. ( think hoyt was in R mode. )
catch board and power it off.
turn board on on the bench, try again. same thing.
repeat again. same thing.
quit metr. connect to vesc-tool
turn ppm mode back to off.
check mapping with realtime data. remote was in flipped R mode and had level 1 mode enable.
flip R mode.
enable mode 3 on hoyt.
mapping looks fine.
enable PPM mode current reverse with brake.
everything works fine.
can’t reproduce.
What could have caused this throttle stuck on behavior? it’s a tad terrifying .
does hoyt have any kind of cruise control I could have auto triggered or? is there a vesc PPM mode I could have set wrong that could make it do this?
we’ve experienced two causes: 1. the early bamboo pucks had a two prong throttle pin that was prone to breaking when dropped. Since the advent of the midnight pucks, this has been beefed up but with a really solid drop or crash, it can still break. We offer replacement parts in the online shop now. 2. the solder joint from the potentiometer to the PCB can be broken (and easily resoldered/repaired) but this generally results in dropouts rather than a runaway throttle.
Crack open the remote and hit us at hoytskate@hoytskate.com with hi res images for review/support.
this was not the bamboo one you gave me. but nice to know pin was updated.
it’s the first one I ever got which I got through lacroix. it’s midnight puck.
what’s this break look like?
will do. thanks.
I’m unable to reproduce this now though having gone in with vesc-tool and toggled PPM mode to off and back to “current no reverse with brake”. makes me think that was somehow related.
board shot across the room. leaving tracks. then pinned against the door and squirmed around leaving more marks. and in two spots… melting yes… melting into the vinyl tiles… didn’t discover that till we tried to clean it up. sheesh.
then clearly not our fault. lolz. you know we’re here for you to either figger it out or resolve any issue with our product. And any resolution is 100% public so anyone with an issue can proactively resolve. Be well, jeff@hoytskate.com
safe start probably prevented that from happening until I pulled back to full brake on the throttle.
Only allow the motor to start if the commanded power has been zero for several cycles after boot, after faults and after configuration updates
Mystery solved. I can have confidence in the board again.
Watch out for accidentally setting that ppm mode “current no reverse”. It would have been bad not to have reverse anyhow. turns out it’s worse before that.
