what the other functions?
I mean if you mean the riding control then yes I think those will work just fine.
you will miss the uncommon features like the ones I mentioned, plus the ability to connect to the BMS. For that you need to use their BMS which is still in development.
This might be ok first gen flipshite remotes have been problematic but this isnāt their work. (Vx2 freezing, couldnāt switch between miles/km, poor battery)
Live telemetry is what I wanted the most.
ah ok that should be fine. I do not see why it shouldnāt work.
noā¦
He is using the meepo shell/casing only. completely different internals
@murdomeek My badā¦ that makes sense
@jack.luis how is the remote? Iām looking for a āboostedā like remote with more throw on the throttle than the vx1. You liking it?
donāt you forget the āconfortable hand touchingā, thatās cheaper than your local hookers
someone got the combo yet? the remote on/off feature works? i donāt care about other features yet, remote on/off is most important for me
This has more throw than the VX1 but with a slightly easier roll of the wheel.
I have it but havenāt hooked it up yet. I can tell you that it wonāt work until they release a compatible anti-spark.
Any issues so far? Disconnects?
Not set up yet
I have a group ride this weekend and donāt want to risk anything while riding in NYC.
No worries, keep us updated!
Hi, Guys, thanks for your trust to purchase new product that without review. guess some of you already received the remote, here is operation tutorial for freshman.https://youtu.be/4p8RSCjJoe4
I have your remote paired and plugged into the UART port on my Unity. Nothing happens. The throttle does nothing. Is there a specific baudrate I need? Mine is currently 115200 bps
oo I didnāt realize separate receiver was available
@hardunclejohn can just the receiver be purchased?
Run the input wizard in VESC tool. Select the VESC itās attached to, then you should be good.
Yes , single receiver is for sale.If you need it.
Yes. I did that. This is far from the first UART remote Iāve installed. I am running a Unity, so I chose the master side for the UART remote.
Does anyone have a step, stl, or 3df of this remote?
