Knock yourself out ( with or without booze)
This is serious seriously, I’m trying to help you you flat-decked ultraboard wonder
I love you Dad, but that is fucking hideous.
Rides nice. Like those ugly chicks.
The less teeth the better.
Would look sleek asf with a lil concave and a better enclosure.
Raw Alu and black looks
tho
Not electric, but I bet someone could easily convert one of these and switch to pneumatics since they use bog standard RKP trucks. Yes that is the correct orientation for the board. Yes those trucks are backwards and flipped so they still turn correctly.
Oh Lord above…8" thanes and inverted Cal II (clone) trucks? That’s something you don’t see every day
What board is that?
Certainly looks like it!
I do wonder if I could do this with any old board. You could probably hit 10" wheels with less than an inch of ground clearance with a double drop deck. Must be a weird feeling to have the platform lower than the wheel axle.
The words stable and difficult to turn comes to mind. I’d be concerned for wheel bite on the feet as well.
Noice! Are those dkp or tkp you got on there?
I double dawg-dare you!
Correct me if I’m wrong, but shouldn’t the trucks be reversed? I think with the current setup it will turn right when you lean left, and vice versa.
Yes, definitely
But I think that’s just for demonstration purposes, proof that’s it’s an “ultraboard”
Looking forward to seeing it! I’ve been wanting to build a low and wide street cruiser, but I haven’t found trucks wide enough yet to avoid wheelbite without going to channel trucks
