moon
1
moon
2
Post #2 KEGEL CORE WHEELS
Diameter : 80mm
Width : 56mm
Contact Patch : 56mm
Durometer : 77a, 80a, 83a.
Bearing Seat : Offset
Formula : Happy Thane
Core : high-strength, high-stiffness, heat-resistant urethane
Diameter : 85mm
Width : 58.5mm
Durometers : 77a, 80a, 83a
Diameter: 90mm
Width: 54mm
Contact Patch: 45mm
Durometer: 78a
Weight: 290g/wheel
Diameter: 90mm
Width: 54mm
Contact Patch: 45mm
Durometer: 78a
Weight: 290g/wheel
Diameter: 100mm
Contact Patch: 65mm
Durometer: 83a
Formula: Hemotox
Diameter: 110mm
Contact Patch: 65mm
Durometer: 78a
Urethane Thickness: 31.50mm
Color: All Black
Weight: 534g/wheel
moon
3
POST #4 FLYWHEEL CORE URETHANE WHEELS
ABEC 11’s
$86.95 ABEC 11 90mm Black Reflys
Durometer: 74a
Width: 52mm
Contact Patch: 43mm
Lip Profile: Round
Core Placement: Centerset
Wheel Surface: Smooth
Diameter: 90mm
$153.00 ABEC 11 107mm Black Superfly Flywheels
Durometer: 74a
Width: 63.5"
Contact Patch: 57.5mm
Lip Profile: Round
Core Placement: Offset
Diameter: 107mm
moon
4
Post #4 OTHER URETHANE WHEELS
Diameter: 85mm
Width: 52mm
Contact Patch: 50mm Radiused outside edge, square inside edge
Bearing Seat: Offset
Durometer:
- 75a Crystal Clear Blue
- 77a Crystal Clear Purple
- 79a Purple BlackOps
- 77a Bubblegum Defcon
- 78.5a Mango Defcon
- 80a Mint Defcon
Weight: 243.80g/wheel
Diameter: 78mm
Width: 70mm
Contact Patch: 70mm
Lips: Square
Core: Offset
Surface: Smooth
moon
5
Post #5 PNEUMATIC WHEELS
Weight: 392g - 0.86lbs per wheel
• 150mm diameter - 45mm width
• Made to fit standard 608 type bearings
• CNC precision milled hubs made out of T6 heat treated aircraft grade aluminum
• Reinforced tire walls for max. inflation of up to 85psi)
Offset billet wheel hubs designed to fit on any skate truck. They use standard size 608 bearings for 8mm or 10mm axles.
Work specifically with Vex Robotics VersaPulleys. Glass filled, nylon 5mm htd 42 or 60 tooth pulleys.
This price includes Tires, Tubes, 2 Versa Pulleys, and Stainless Hardware.
A set of wheels with two wheel pulleys weighs 4.85lbs (2.2kg)
moon
9
Post #9 ESK8 specialty decks (support the community)
— Message Bevilacqua To Buy
moon
11
Post #11 Enclosures and mounting hardware
— Mounting Your Enclosure
@BIGBEN Enclosures (UK)
Landyachtz Evo 39/falcon 40 - single stack
Landyachtz 9two5 - single and double stack
Landyachtz switchblade 36 - single stack
Loaded Tesseract - single and double stack
Earthwing supermodel - double stack
Tayto/spud - single stack
Hummie decks - single and double stack
