Ultimate Beginners Resource Book
Post #6 CALIBER PROFILE TRUCKS
Caliber Trucks Cal II 50° RKP Longboard Trucks
  • 44-DEGREE CONTAINED BASEPLATE
  • 10” AXLE
  • 184MM HANGER
  • BLOOD ORANGE ULTRA-HR BUSHINGS (89A)
  • INSERT BARREL + BARREL CONFIGURATION
  • GRADE 8 STEEL KINGPIN
  • DESIGNED FOR HIGH SPEED AND STABILITY
$70.00 Caliber E 184mm 50 degree Truck With 47mm Extended Axles
  • 47mm axle on each side
  • 184mm of aluminum hanger
  • 278mm total axle length
  • Includes 4 speed rings and two axle nuts per truck
$65.00 TORQUEBOARDS 218MM TRUCKS
  • Truck Length - 12.36" or 314mm (including axles)
  • Hanger Length - 8.58" or 218mm (not including axles, only hanger space)
  • Axle - 47mm Length, 8mm Diameter Axle
  • 10mm Thread Length
  • 37mm Usable Axle Length (Standard longboard wheels will need to use a bearing spacer to offset the 10mm added axle space due to the longer Axles.
  • Material - Die-casted Aluminum
  • Weight - 1lb 3.4oz (Single Truck)
