Brand new unused…
@Acido does the battery im buying from you fit into this?
@MauveMaverick Do you know the max size battery that fits in this? (With say dual foxboxes and a bms)
Depends on the BMS.
Enclosure is roughly 63.5cm long, 14cm wide at the narrowest end, 18cm wide at the widest end and around 3.5cm tall.
I think 48 cells is around the max you could comfortably fit without knowing more details.
Internal sizes. 620mm long. 140mm-170mm wide. 25mm deep.
… In my defence I did say roughly.
Height and width wise it will fit, you should have space for other electronics as well as its ~45cm long
Ehh, it’ll probably work out xD
I’ll take it, PM me
Bumpidy bump bump, still available.
Weekly bump for visability.
Is this still for sale
It is indeed, that’s why I bumped it
What’s it made from and can it fit 2 layers of cells
What can to the total capacity hold?
My board is slightly curved on the bottom?
If your deck isn’t a Landyachtz Evo, this enclosure will not fit your deck well.
Hold on will get an image
https://esk8-news-objects.s3.dualstack.us-east-1.amazonaws.com/uploads/original/3X
It’s not going to fit that deck unfortunetly.
Darn it.
I don’t recognize that deck, but if its a popular make/model @BigBen might be able to make an enclosure for you. If not probably better off looking at making your own, ( this thread is a good starting point) or buying a ‘universal’ enclosure, though I am not sure how well these work out in practice.
I did buy one but it didn’t fit very well, I am just in the process of making one out of fiberglass just can’t get it done
