I suppose this is only realistic with new parts
This board was 500 bucks (minus davega)
i ruined the battery by leaving the loop key in and am rebuilding it rn
It’s still realistic because it’s often not fast at all to scour the parts markets daily until the items you need come up for sale at a discount. So that’s “good” and “cheap” but not “fast”.
I disagree but this derailing too much
The thread title is “Trying to build my first esk8 for cheap.At the sametime, High quality.”
That’s not offtopic at all.
This motor’s performance is underwhelming. Better go with flipsky BH 6354 190kv.
Not if you fully enclose everything, if the enclosure isn’t enclosed. The electronics are on the bottom so you’ll still be able to get signal if you don’t put carbon on the enclosure
The thing I learned from building my first board (well finishing ) is however much you want to put into it. Cheap or not. There will be extras that is crucial and will put the budget more on the ropes so that’s another thing, make sure you got everything you need and not missing anything
Besides the part about it being silly to use a radio-blocking material, on a vehicle where your life depends on the radio signal. Besides that — glass fiber is actually more flexible and less rigid and has properties better suited to skateboards than carbon fibers which are extremely rigid and inflexible.
You’re basically saying “put the radio blocking stuff only partially around the antenna” when your life depends on that radio. And also when the radio transparent stuff just seems to work better for this anyway. So why use the carbon at all?
This discussion constantly comes up over and over and over and over and over and over and over and over again.
Carbon sounds and looks cooler, this is the real reason methinks.
Carbon is more dependable for less flex if your supposedly made of money and can buy batteries left and right (for my case lipos) minimal flex is appropriate but not to the point where the board flexes and scrapes the ground like a low rider. Possibly damaging the electronics in the process. There’s been some people on the forum that has used cf or unidirectional cf (what I’m using) and haven’t had any issues. If you incase the enclosure with cf, yes it messes with the signal but if you have foam over the opening, the enclosure not covered in cf it should be fine. Based on what I’ve been told
There are also people who stand on top of hot air balloons and don’t fall off.
I’m not convinced that should be the basis for advising someone about something that can impact their safety. ![]()
in short, no carbon
specially for not $500 or less
It’s just a suggestion. If he makes an enclosure with carbon fiber infused. That’s the possibility if he’s looking for appearance or safety. It’s the choice in the end if you’re depending on safety or making your board look bad ass. Same time knowing what the possible consequences are if you go the bad ass route more
I believe I have a few new extra p26a kicking around to help out with this. I have tons of used ones. But if I build a used pack I like to ride it hard for quite sometime before I ever even consider selling it. And I always make sure people know, “this one might look pretty but it’s used.
Dude I have been looking for this for a minute… thank you.
@Darkstar826 here you go, my dude
Along with what @b264 Brian said, i have 6355 motors that I can get you cheap. Size is not an indicator of performance BTW. Just how hot they run.
Dual 6355 will rip your socks off.
For a low budget build though a single 6374 is enough.
That 30q battery, the 2x TB 4.12 and 2x 6355 is a great price. $225 vs his $350 currently budgeted. Better range and performance, and leaves money for BN motor mounts. Really hard to beat that
