Looking to upgrade to dual motor. Trampa’s new motor mount doesn’t accomadate 8" wheels for mini spring. Just need a single motor mount (goofy) for mini spring. or i guess a dual motor mount if not too expensive
Or interested in buying their mountainboard truck with motor mount.
woops. USA. THanks. I’m talking with Idea about his motor mounts which will run me 250-300$ looking for 1-200$. just need goofy mount but will by a dual if need be.
new trampa mounts are about 100$ with wheel pulley and motor pulley, but they don’t fit 8" wheels anymore and want 8" wheels bc they are cheapest
Thanks @bboybowzer. wow I didn’t realize how big the Trampa mtb trucks are…16". sorry but I changed my mind and want to stick with my mini spring bc im urban, sidewalks etc.
But id be interested in the mounts… any idea if they work with mini spring too? oops sry for the pun
Their new mounts only allow up to 7" wheels. There are tons of cheap 10$ 8" wheels on amazon… But 7" wheels are hard to find/expensive.
Also you can find Trampas old motor mounts on their website but when you go to check out it says no longer available.
I also called trampa twice and talked to them about it
hmmmm true. good point… evolves are only 15$. I could do 7 inchers in back and 8 in front…
idk tho, tires sometimes wear fast. im trying to make this hobby affordable long term, but ill consider that thanks
They do fit, just need a different length cross bar.
I had mine on mini in the very early days, than moved to the bigger hanger and just ordered a custom carbon fiber crossbar in the right length. Easy and cheap.
I need to look, but I think I still have the original crossbar for mini trucks laying around I could send the OP for free if he pays shipping.
Not sure if that makes sense from Russia thou.
Probably cheaper to ask for a crossbar cut from CF.
Edit:
Just checked their site and didn’t see that had the Cnc milled ends. The IdeaTB mounts I bought were for the Cnc milled trucks. Which are more narrow then the standard trampa hanger. I don’t have a mini spring hanger to compare if they are the same as the Cnc ones
Ah no than no. I thought yours are for the regular hanger, not the cnc.
Still should work if OP would be ready to lil bit file down his hanger, but at this point I personally anyways would have bought just another mount of trampa
Haha I know what you mean. I was gonna use them on kaly hangers since they looked squared to me. Didn’t fit so I bought the Cnc hangers wasn’t that much to me.
