"Trail Blazer" My Trampa / MBS Hybrid ATB
I’m sorry I didn’t realize that until now :man_facepalming:
So I don’t think Dual Lock is working, something to do with the extreme flex of the deck. Might have to bolt it down Trampa style
b1a74481877ccdbd8ebec41ea0426669a214f991_2_281x500
Battery box has been bolted down a-la Trampa style with Clevis pins and clips. It’s not going anywhere but it does tilt forward and backward a few degrees and hits the deck which will make a racket over any bumpy terrain. Wouldn’t have been a problem if I didn’t grind off the feet. Live and learn.
I’m going to use old bushings as replacement feet for the box.
Just pump that s*** full of silicone or hot glue lol
42 real world is awesome man, turns out Dr. @Arzamenable doesn’t just help sick people he helps sick boards.
Jk of the day and made my day!:rofl:
I had some of those too but decided that the rattling might drive someone nuts… but u are on chains, so moot concern.
Why pins instead of a pan head and nylock?
Seemed an interesting way to do it. I suppose I also don’t have to use tools if I want to take it off.
Hmm, its definitely interesting. I used to have mechanical brakes on my longboard with those pins keeping the main lever bar anchored and I lost both of them after about 100 miles. If you use a bolt you can at least tighten it so the bushings are in compression and it will wobble less
It’s under a fair bit of pressure already. I had to really squeeze to get the clip in the 3rd hole on the pin and while it’s not as tight as a nut and bolt can be it should be fine. I just wonder how long the hot glued bushings will stick.
You should put the bushings on the pins holding the box
Haha, first do no harm. :grimacing:
“Paging dr deadshort”
Changed battery amps from 60 to 80, really rips now.
On another note, the griptape I put on the Yobis absolutely destroys my shoe laces after a few rides. I’ve gone through like 5 on one foot already.
Yaass queen
where did you get the grey giant box?
Would you say the “pelican” type boxes are better? (ease of use, more robust, convenience, etc)
I got the old one from polycase. A bit pricey but it was a good box. Just wish they included hex bolts instead of Phillips
Having a latching hinged lid is so much more friendly though. Don’t have to worry about bolts, it just closes and opens.
