A13XR3
June 20, 2021, 5:06am
765
I think the better way to spend that moeny would be to buy abec or pneumatic wheels. There’s no telling weather or not that would happen again and while their warranty may cover it probably not worth having to deal with this again.
Not sure how common this is, but you’re definitely not the only person to experience it.
wh4ck
June 20, 2021, 6:11am
766
Seam Grip anyone?
Wouldn’t work if there’s silicone involved though.
Seems to be kind of random but the most recent batch (namely 72a ones) seem to have the issue more frequently
I have like 500 miles on my 74a ones from the first batch and no signs of delam
That is sooooooo not safe!
b264
June 20, 2021, 8:57am
769
I think it is the last batch
Hello been looking at these for a while are they any good looking for a soft wheel? may go with the 100mm wheel
Thank you
b264
June 20, 2021, 1:20pm
771
All the kegel cored TB wheels except the last batch of 110mm 72A clear blue seem like great wheels, yes.
OK thanks will hit the trigger
Do you know if dickio sells wheel pulleys for them?
Linny
June 20, 2021, 2:26pm
773
He does, they’re nice. I have a set of 40T ones
Thanks, is a 36 tooth one OK?
I have 190kc motors
Linny
June 20, 2021, 4:37pm
775
It’ll be fine, i like extra torque on my set ups, i am running 14/40 on Caguamas, because its on a single drive.
Thanks might try a higher motor pulley wheel
frame
June 20, 2021, 4:42pm
777
Linny:
40 on Caguamas
40? what’s ur clearance at
frame
June 20, 2021, 5:01pm
779
looks to be 5~7mm, good enough
DIwhY
June 20, 2021, 5:58pm
780
Roughly when did the last batch begin?
Is there anything wrong with the 110 wheels?
Not sure what to go with 100mm wheels are a bit narrow
Are they 100mm they look pretty wide, website says 52mm wide?
frame
June 20, 2021, 11:09pm
783
That’s not tb100, its dyed cag
Yep - I agree with ya there. 110’s are wider
