That’s legit.
@tomiboi have you considered making spacers for the hubba hubs at all? I know they’d have to be spaced inward but an extra 5mm or so on these meepos
would be
Spacers? Like to make them wider?
Yeah, some guys have been making them for the mbs pro xl. I think they would go well on your wheels.
I can certainly design one to print.
The Hubba-hubs have a 52mm inner width. They should fit the Meepo tires well. They fit the XCell RS tires.
Yeah I’m just picking hairs really. They definitely pull the meepos flatter than the cyclone hubs. Still a bit to go though before they’re really flat.
If you do, I’d definitely be interested in a set
Our of curiosity, what are your reasons for wanting the tires “really flat”?
Wider contact patch. I don’t care about consumption
For me, wanting wides is for more traction , the 4wd requires it
Hey @tomiboi what’s the bearing spacing for hubba hubs?
22-23mm
Yup, 22-23.
early batch is 23mm anything recent should be 22.3mm iirc
correction: up to today (check date on the upper right corner of this reply), 23mm is the correct size
I haven’t had problems using 22mm spacers, but I’ve been told that a 22mm spacer plus 1 speed washer is spot on.
did this happen? if not, then 23mm is the correct size.
I’m still working my way through the first batch.
more people need to buy these awesome hub!! ![]()
Just more photos of 200x75 qind on hubba hubs.
The qind tires are a great fit on the Hubbas.
