tomiboi-Esk8 Ratcheting toe-clips are in stock!
Awesome. I look forward to trying them out. Loved your video with the abusive testing!
I enjoyed making that video :stuck_out_tongue_winking_eye:
you should have smashed a couple of sb and 3d printed bindings to pieces to show the progress.
Could some of the features be simplified and then have it CNC cut? prob a waste of money unless they were in a crazy rush.
CNC aluminum would get a little pricey. I’ll look into speeding the baseplate along.
Just pick it up mate
Well, my buddy decided to order some of these for me!
Guess I’ll be checking these out soon.
I am not using the stock rubber spacer, I cut up a bike tire and used that rubber. Therefore I tried to put a stopper for when the board flips preventing the rachets from going all the way down. This did not really work well the way I did it with a wood screw randomly stuck into the binding.
What worked better was picking a pebble up off the ground and crushing it into the deck under the toe clip. No more bindings ratcheting when you don’t want.
A ratchet-lock would be an interesting feature.
What’s the idea behind the gasket?
Is it just to conform to the deck?
Yes, exactly.
I’m a dum-dum and lost a T-nut.
Spiked one or non spiked one?
I can send you a new one.
I’ll probably find it, if not I have a bunch of not-as-cool ones around. :frowning:
Well, I made a video.
Just keep it a secret that I’m missing a T-nut this whole time.
lifesaver! i will totally use this.
@tomiboi after a week of using my toe-clips, most of the foam on the underside of them has withered away. Is there a suitable replacement? My feet dont feel very secure anymore.
A few people have reported this problem to me. I had actually upgraded the foam to a “more durable” option, but apparently, it’s not durable enough.
I’m looking into silicone or a soft rubber instead. In the meantime, I’m happy to replace the foam. Otherwise, you might try DIYing it. You can buy rolls of adhesive-backed foam or silicone on Amazon for cheap. Then you can customize the pad to your liking and have a lot of back -up material should you wear through them.
Yeah I have tons of neoprene, I was just thinking about rubber or something more grippy.
