You’re very close but I have a triple stack enclosure goin.
Okie Dok. Time to unveil what a lot y’all have already been seeing. This is my big fast af boi. I’ve decided to name it Dream Chaser because of several factors.
Anyways, it will be boasting a 20s6p with P42A cells and controlled by twin tronic 250’s. I plan to throw at least a front binding on if not both. It has @Skyart 135 kv 7490 motors and rocks a 9:40 (4.4) gear ratio. The wheel sets are both 200-215 mm (8-8.5 in). The drivetrain is all from @3DServisas and is the finality setup anodized in blue. The deck and enclosure are both from @tomiboi and are very big and wide for my fat ass. I’m planning on running as much power as possible through this system for esk8 con. At the time of posting this, it is programmed and almost ready for its maiden voyage but I still need to finish up a couple things.
Specs:
20s6p P42A (180amps battery total)
Tronic 250’s (250 motor amps each side)
Skyart 7490 135 kv
Finality 4.4 gear ratio on 8-8.5 in tires
Lmk what y’all think so far!
Hot dawg man…the sound that thing makes ![]()
Yeah, it sounds like a jet engine. You knew that though since you’re basically the godfather of this build.![]()
Niiice sounds sick. Daaamn nice build, sounds like it’s about to be a lot of fun. You plan to take it for a spin before Esk8con?
Now you’ve got my interest.
Although is this the final height of the triple stack? it seems kind of low to be a triple
Maybe the photo just makes it look smaller than it actually is though
This was while I had it open and the spacer wasn’t in place yet, they other pictures show the spacer better
If the weather permits, this is what my mountain looks like that’s less than 30 mins away.
Holy torque. This deathtrap has peaked my interest.
I can’t remember do you have metr in that set up? Would be cool to see how many amps were pulled during that little trick
Holy crap lmao
U gotta let me try this at esk8con
It would only be fair Secret Santa!
I am not ![]()
DAaaaaang, we gotta get you one
Eventually broke off but it lasted a good while, I ended up getting some shaft collards to go around and then put JB weld on too. That seems to have worked.
