Why would you not install them how they should be? There are 6 bolts on them for a good reason. They need 6 bolts. I would point in the direction of the @torqueboards bolt on 36t pulleys but the pain watching you try to set them up would probably give me a heart attack.
The problem is not just the bolts.
The two sides of the pulleys should interlock,something they were not doing as they were installed.
So the outer plate is not aligned with the holes in the wheel? You serious? @Halbj613
have you never had one of these things?
I was wrong… sell it all and buy a prebuilt. You seem to want to ride right away rather than taking the time to test and fix things. You could end up hurting yourself riding on a board with a lot of problems because you so badly want to ride
I ran out of bolts and therefore decided to just test with four
I didn’t think it was going to brake
Where can I get a replacement within Eu
So I don’t have to pay customs and wait weeks on shipping
Believe me I wouldn’t mind selling my stuff and doing that
I think I might just go forward and sell
I got a friend called van dijk
Wonder if their related
I found two old ollin pulleys which I had
Which are great except they are 12mm would they work on a 15mm belt
Or would the belt break
Just asking calm down
They seem to think it could work in theory
Don’t tell us to calm down, fucking read
What do I search that’s all I could find
Do you know whether it will work or not
I mean it could work temporarily but I’d imagine it makes your belts wear out quicker.
Also if your stuff’s not perfectly aligned that belts going to walk right off.
There’s probably not a whole lot to find through the search function on this because it’s not something most people would consider trying.
As in would it keep me going while a proper pulley is coming
I don’t know if I would ride it.
Something I would personally only result to for mocking up assembly while waiting on proper parts.
Anyone in London/England willing to print some pulleys for me since
Those ollin ones didn’t fit the belt either way
I need 38t pulley*2
I live close to cambridge and can print those for you if you provide an stl…
