Huh
This is true though… bigger battery = longer riding, how can you argue against that
Huh
Jeff Wu had a severe case of schizofrenia, was not his fault guys. He just got better and dissapeared.
#hisjourneymatters
“Esk8 Builders forum isn’t dead”
How you gonna argue against Poppa Mooch. He’s right in ways you don’t yet comprehend, lil fetus. ![]()
rocket fuel dilemma
You are correct
But his statement goes against why we even build batteries that weight 25lbs
Obviously 10s2p of P42a goes less distance than 12s12p
Funny but also we aren’t fighting gravity so less relevant
Yeah yeah, and The Empire Did Nothing Wrong.
Isn’t @ShutterShock older than all of us? Grandpa yeah?
your mom goes less distance than a 12-12p
Run a 50E at 25a and a p42a at 25a and come back to us with the total usable capacity of each
The point is that manufacturer rated Wh/capacity is irrelevant if the cells can’t provide it for the given load of the application.
Oh well if you are comparing different cell types that’s a different argument. In that case it makes sense
AUGH FAM why
Right right I misunderstood. Full steam ahead
What do you mean my 8000mah 18650 battery from “Ultrafire” isn’t going to give me more range???
showers after a fresh road rash meat crayon moment are the best
He broke out of his retirement home.
Evolve hadean is the strongest production board
the aladeen can outperform a Sur Ron no competition
Easy…
Take a pack made with ultra-high capacity “energy” cells with low current ratings and lots of voltage sag and put that up against a same-size pack using lower capacity (lower Wh) “power” cells.
At anything above a few amps per cell and the lower capacity/lower Wh pack will run for longer due to the reduced voltage sag you get from it.
He’s calling us all fat.
this why I lowey go back to lipos once in a while
the lack of sag is fun, until it’s too late
In my attempt at a defense…does the shoe fit? ![]()
