The ULTIMATE Electric Skateboard Kit
MR are a better connector. The MT tends to lose the rear shield easier. They are both good really but the problem is if you run unsensored then you need to physically change the phase wiring if you have a reversal and that can be a pain in the arse.
Sorry I made a mistake MR xs XT
I get the benefits with the 3 prong
But how is a 2 prong MR going to be any better?
MR is 3 prong you weapon
I am buying this Duel Kit of yours! This should complete my esk8 collection…so basically, you complete me :grin:, and you had me at hello, or rather $750 bucks. Serious question, I’ve got an old 10s5p 20700 SanyoB segmented pack from a Lacroix DSS50, do you think it would fit along with your duel ESC and BMS and the other tidbits? It looks like 10 of the 20700B measures 8” wide. Not sure how wide your enclosure is.
:call_me_hand:t4::pray:t4:
Ok Ive just realised what I’ve done.
You made me laugh is what you’ve done. Phase wiring for unsensored is best served with the MT because it is easier to adapt the connector to spin through one plane and therefore swap wires. You just have to dremel off the locator bar on the female
XT is 2 pin straight.
MT is 3 pin triangle.
MR is 3 pin straight.
MR60 uses 3.5mm bullet connectors.
If you haven’t tried MR60, you should.
60 is 60A continuous. 90 is 90A continuous.
So MR60 is 60A continuous (120A peak) 3 pin straight, which is perfect for a motor phase wire connector.
I just posted a picture Brian. If a picture paints a thousand words then why can’t I paint you…
What he said.
I do prefer getting information from pictures and photographs are even better, but in some cases I would prefer text so, for example, I can copy and paste the part number into AliExpress or Banggood
Actually thanks I did know EC5 3 pins (cannot be found anymore) and MT60 but not MR60, Ok now I want one… But already have thick cables and 5.5 or 6mm bullets at home (need to measure)…
I don’t wanna do the model but need it… Fine I’ll do it…
No :smile: thats 50 cells that are larger than the 30Q… maybe double stacked with a fancy gasket, but it would take a LOT of tinkering.
would that be like a french girl or body paint?
You made me vomit in my mouth at the thought of Brian in body paint. Cheers. Thought we were friends. Now I know.
@BuildKitBoards
So for international would be buyers of your kits could a battery less option be feasible?
My son has a birthday coming up and this would be perfect for a dip into the actual makeup of what he loves in his meepo. Good father son bonding thing too but don’t let my obvious emotional blackmail sway your decision but think of his little 11 year old face on his birthday when I tell him you said no…
The short answer is yes, but I won’t be able to do it in the first 25 kits. Batch 2 is certainly a possibility. Let me make a call today, I’ll see what I can do
Wow powerful move lol
Kits are up, launching in less than 5:
Rooting for you. Good luck!
TBH I’d buy it. Awesome kit!
How are you getting 20 miles off of 10s3p? Are you going full speed or 20+wh/km?
Going moderate speed, 12mph. 20 miles is maximum range. If you go full speed, your right around 17-18
