TB bolt pattern is different to trampas
Not sure how this is going to work
bolt pattern is the same i checked. only thing i need now is a 9.5mm22mm bearing
That’s odd that it works since the TB bolt pattern is 73mm
And trampas is like 71.5mm
@Trampa hey Frank wondering if you guys are shipping, or still on lockdown, I need some of these 9.5x22 bearings
i have my fingers crossed for you
i can’t tell from your pic, what’s stopping the wheel bolts from fully screwing in onto the wheel adapter?
UPS is back to “normal” if that word is appropriate to use in these times.
What was your build time on this, looks cool!
Still building lol, I ordered these bearings that I needed should be here in a week or two, hoping to be done by then
Battery is done! Tommorow will mount to deck and hopefully get all the electronics connected as I wait for the correct bearings to arive
Be careful. Make sure you have all safely set up.
Mine isn’t connecting.
Did you try pressing the fix button. Lol
Update on the smorg…waaaaay to low! Going to rearrange the bms to the middle enclosure AND get risers…now does anyone know where I can get risers? Also how flexi is too flexi? Cause I think I might be fatter then I thought
got a pic of you standing on it, or a video of you getting on and off?
