The real reason 6 shooters always puncture tubes
Like all Psychotiller products, from across the room they look like the full biscuit, but as you get closer you begin to see problems.
With my 6 shooters I could actually see problems from across the room, so before Inflating them I decided to pull them apart and have a look.
What I found shocked me, and pissed me off at the same time. To call this bad work is an understatement. To call whoever did this a cowboy is to disrespect cowboys in general, in fact its even disrespectful to cows.
So when I opened the wheel up I saw this. Razor sharp edges everywhere, especially where the valve stem is supposed to live
Complete with swarf shavings all over the tube
This bearing was even pressed in with a big piece of swarf stuck behind it, I had to press it out and clean it up, a heat gun worked well to expand the aluminium wheel and luckily the bearing came out fairly easily.
So then I got to work cleaning and rounding off all the sharp edges with a die grinder and sand paper
And thats when I realized the REAL PROBLEM. The hole in the wheel is too fking small to let the valve through!
So I had to go back at it with the die grinder and open the holes up so they were big enough to let the valve pass through
If you give him a couple of months he might say he is sorry
Good work, even DIY part’s need a little extra DIY sometimes.
I have to finish off with phone pics.
No fit
Fit
After making sure all the valve stems could pass through the holes I cleaned everything and lubricated the area with silicone grease, then fit them back together.
And check out the witness marks on the brand new bearings.
Hes off my christmas card list already
Bless Dave, taking a beating at the moment and it’s well earned.
Looking forward to all the replacement FleXL’s though, that paypal account was unlocked 2 months ago so we should see them flying out the door soon :crossed_fingers:
All of the problems I have with his stuff has to do with him not giving his jobs the time they deserve.
Wow does that mean he paid what he owed people who used PayPal?
Not backed up by facts, emotional response. I learned a long time ago to stop listening when someone says ALWAYS or NEVER.
You just said ALWAYS, and NEVER. . .
No mate, only joshing
Then stop listening.
so sorry bud that your order arrived in such shape
it’s a good thing that consumers have choices when it comes to pneumatic wheel hubs for skateboard axles (six shooters are unique though)
I had to do the same on my 6shooters.
However this is not the only cause for leaks around the valve.
Apparently some Clever tubes suffer from poor bonding of the valve to the tube.
I had more than one valves detach in that area without even using them.
I’ve opened up haggys and six-shooters
Both have sharp edges unfortunately
3ds makes wheels with 22mm seats (for those who want them), they quality is on point
although you can’t use clever tires with them
Lmao. People want perfection at pocket change cost. Y’all complainers Don’t be afraid. take your Wheel design to a machine shop and let us how it goes :rofl:
Didn’t haggy put those o-rings on their valve stems for this reason? I dont have those sixshooters but a few of my buddies did own them. None of them had flat issues.
okie fran
They just need a cheeky tumble Franny. Not hard to finish a product before you charge people for it
