With a battery that big are you planning to just run it between like 80%-20% at all times? Could improve cell longevity and (IMO almost as importantly) stay within the much flatter part of the discharge curve. Much much less of a difference in performance between “full” and “empty”
Have you considered adding an xt90 with full pack voltage available? Then you can plug your board into an inverter to power your house during a power outage.
not sure if that will be the case, most pessimistic guess is 150km. but be sure I’ll find out how much I can get.
you brought me to an interesting idea - do you know that feeling when your battery is almost dead, but you need few more kilometers so you move your cutoffs a bit?
if I set cutoff start to 3.2/cell and cutoff end to 3.1/cell, drain the battery to that point, and still need a few more kilometers to get home, I’ll still have 1.5wh on each cell, about 500wh in the whole pack - that’s like 20 more kilometers I might be able to go full range of some boards
might try to tinker a bit with max/min voltage to keep the battery safe, but to still have the option to max out the range with slightly overcharging and slightly overdischarging it. I think it’s essential to know the capabilities
I’ve added single 14awg line to be for direct charging (bypassing flexibms) to allow me charge faster than 10A without balance. theoretically I could be able to charge with 140A, but I have the system not designed to handle that. the 14awg wire and 25x0.2 strip should handle 50A, and my fastest charger does 25A.
also, I’ll be able to bring TS100 sodering iron with me (with step-down) for longer trips, and plug it to this port.
regarding the inverter-power outage situation - I live in Prague for 4 years, and I’ve never had to deal with this
You could also power a campsite or charge your buddies boards haha
Well for me 15% is around 30km so around a full charge i get closer to a 100km before any noticeable drop off and then never pushed that long in a single charge but I would guess 120km if in one sitting, you should be way beyond 150km even 4wd, sure you take more amps because more motor, but also each motor has to do less work, biggest energy loss for you should just be raw weight, as 12s28 is just massive.
As to answer your question, I dont know, I have a soft cut off at around 30% and the board just gets sluggish but the batteries keep giving without issue, yet again you have such massive battery it should never be a concern.
it is
buttake in account I’M used to 150A on these motors sure I’ll make them suffer teribely
that is actually true, and imagine scenario where the conects exists, and how many kilometers you can still get on it. i’m really looking forward to testing this
My first build was a 12s4p with 26650 LiFePo4 cells that could each do 50A continous and 120A burst, they were more than plenty to haul my ass to oblivion, I think the biggest issue you will have is just sheer weight of the board, as you + board + just everything else securing that battery will increase battery consumption.
Just a thought are those fatboy hangers 8mm or 10mm axels, honestly I could see them snapping or bending with this high amount of weight, you are really pushing these builds in a way I never imagined
the battery prob only weighs 20kg or so (1/5 of the weight of a human) it shouldnt be that much of an issue on the axles
I have seen people bending 8mm Axles with just their body weight, 23kg battery + 12 kg board itself is just 35kg, then you need to also consider the board being so heavy will make it really in the danger zone for so thin axles, hopefully the rider is somewhat light but say he’s a “hefty” 90kg like myself thats 125kg on those axles, wouldn’t take much at speed to bend something.
My fluxx build has 12mm Axles and has less than half the weight of this board.
This build log has me feeling all sorts of ways…so exited/scared/concerned to see the finished product
fair enough
my point is that if the axles are designed for a standard (reasonably large guy - 120kg+) they should be fine with this
maybe 10mm axles would be better
Holy god that is a big battery, excited to see how this all turns out!
well, I started this before the finality trucks were available. imo they would be a better option. we’ll se how things go
and this is how hours turn into days, and days into weeks. finally got myself some free relaxing time around the board
poor me. but it’s starting to look a bit more like something to ride now. tomorrow two magic tricks will be shown.
(screws in truck holes absolutely temporary)
perks of RKP trucks? this much play does not feel good. the bushings seem a bit loose on the truck (lightly tighteded atm). some urethane thingy on kingpin that some budget boards have might help. this started when I turned buthings so that the side which was bottom their mold is hanger-side
If the bushing seat is sized correctly for the bushing then theoretically you don’t even need that small lip / separate bushing in the hanger. But yeah, I guess if tightening the bushings more doesn’t help then one of those things would. Surf rodz have “surf-keys” which are just 3d-printed spacers. So maybe that’s an option, lol.
From what material should these spacers be printed? TPU or PETG? I want to try them on my TB218 trucks.
Absolutely shouldn’t be that way.
What bushings do you have in there?
Holy shit this is a THICC boi
stock 3d servisas
