The shorter button style is the same diameter as the long one correct?
Yes both 16mm.
Hey @YUTW123 Iâm having some trouble with my DV4S.
When connected in VESC tool I canât seem to get the DV4S to connect over CAN, each side works individually but canât program together, or be controlled by a single remote. Any diagnosis steps?
Coming to carvepdx? I can try and help out
I really wish I could.
Next year when funds and injury recovery will allow, I swear.
Re load firmware. Do it 1 side at a time with a cable. Then donât use the app. Setup by cable.
Check the CAN ID of each side and make sure theyâre different
And make sure to flash bootloader to each side before doing firmware
Is there anywhere I can find more information about how to do this? Everything Iâm seeing in relation to bootloader is how to flash using ST-link, is that a new alternative method to whatever is standard or is that a necessary part of flashing the bootloader?
In the vesc firmware section thereâs a bootloader tab. Upload the generic one. USB cable
Why not? the 75100 Alu PCB also just has 2 fets per phase (one high one low)
having massive issues on the 6.02 firmware from maker x. motor detection does not work. anyone else having the same problem?
Did you update the firmware yourself? If so, you must flash bootloader before updating firmware otherwise motor detection tends to fail.
Why? Makerx doesnât come with bootloader?
yes, mostly
I donât know, but if you donât it just doesnât work properly. Trust me I know
Or you can just leave it on stock firmware since changing it is little point
Just typical makerx things then?
typical
yes
Whatâs wrong with using the generic bootloader in vesc tool?
Nothing, thatâs what u should use / flash in the makerx vesc.
