I am certain you can figure out a solution if you put your mind to it.
I thought about it before I designed the packs and decided to try first the back mount version. The 18650 packs already 85mm high and a esc box would add another 35-40mm on top. Don’t want to go that high as well. If back mount doesn’t work out I can always design an other top lid of the battery box and mount them back in the middle.
Gorgeous build! Makes me want to build the parts I’m collecting that much more! I do wanna know if you have a link or a file for the plugs. My buddy 3D prints for me and could make them for me, I want to plug the ones on my street build
Thx! Which plugs exactly you speak about?
pm me your email, i can sent you the stl file.
Ohne interesting old school lesson I just found about the right way to jump:
Meanwhile I changed the Focboxes center mounted to Maytech 6.6 rear mounted.
Those are huge but I like them a lot.
I run them at 80A bat max and 90A motor max.
I as well changed the positive ramping form 0.3 to 0.1 sec as well as the throttle curve to +15%.
First ride the board shoot out twice under my feet (with my feet straped on for sure
Way more power faster available.
With this setup I really don’t see a need for bigger motors (for now).
Not on mainly flat/ slightly hilly terrain.
Next thing to do:
Change the maytechs to the cheap focers to see what I can get out of them.
very nice build and write up
keep up the good work
Ah I can see I’m going to be watching that over and over and learning hahaha thanks for sharing!
I noticed in the video for BH the motors they do the stator and bell, is the bell needed for eboards? Wouldn’t that keep a lot more heat in, or with the bottom open would allow enough airflow? I may go ahead and do mine while waiting for parts
Also what epoxy did you use to keep the fill plugs in the board? The 8 in the deck where the feet go? Got a buddy printing mine out and figured I could gather supplies
I mainly hardened the bell as I had issues with magnets and retaining ring getting lose.
I think for most of us the stator is the thing which doesn’t need to be hardened as long as you don’t have lose windings or shitty glued sensor wires.
For the holes I used just a normal epoxy. Nothing fancy. Maybe get some which is not super fluent. I think you could as well use silicon or sikaflex to fix them.
Amazing board and fantastic riding man, I wish I could ride that well!
Thx! You know in videos you always see just the best parts who know, maybe you already drive better than me
I cant jump like that or do those wheelies so maybe not! Haha
We can just find out when we drive together sadly i‘m not in Paris
Wish you were… dont make me come to Russia Andy…
actually…
You always welcome but summer is short here, winter is also fun if you want to drive my quad
Well, both of you come to Greece. Summer doesn’t get much longer than here.
