Decided to build something a little smaller and more portable than the Toy’s R Us longboard.
This is a Landyachts dingy board to build it from. Maytech trucks and wheel motor.
I have an Ebmakers mini VESC coming and the batteries will be a pair of Dewalt 20v max batteries. I have a few matching sets so I can run tiiny 30 wh packs or a pair of 100 wh packs. The mounts will be based on a Waitley battery adapter with some 3d printed parts epoxied in to make them survive on the bottom of a skateboard.
Here is one of the battery adapters. In this picture I have removed the top part that fits into the old XRP stye tool. The contacts in these are rated for something like 30 amps so no problem with two of them feeding my tiny little hub motor.
I know there are files online to make one brand of battery work with other drills so you may be on to something with the most universal power plant around.
Idk how old you are but on Monster Garage (w/ Jesse James, they had an episode sponsored by Milwaukee and they built a drag car with something like 700 batteries in the trunk. Shit was crazy in 2004.
I would say that facing sideways might give you less chance of the battery coming loose. If its parallel with the deck, then accelerating and braking is putting force directly on the locking mechanism. If the batteries are sideways (perpendicular to the deck) then the force is applied laterally to the rails holding in the battery.
