The Definitive Guide to Metr App / Metr Pro
Sorry, but this doesn’t make any sense even if I try really hard. You don’t use Bluetooth to connect over USB. Firmware of USB module? What’s that?
Please send some pics of the errors you’re getting.
Anyone know if there are any plans to add support for the app to work on the Google pixel watch 2. Would love to have stats on my watch
Does it actually not work on the Pixel Watch 2? It’s just Android Wear so it should be fine. I have it on a Samsung Galaxy watch which is also WearOS 4.0 like the Pixel watches.
Nope it’s not available on the watch 2. Also the watch 2 doesn’t allow you to use the wear os app. You have to use the “watch” app. And through there the metr app only shows available for “phone, tablet, Chromebook”.
Have you tried enabling the Android Wear setting in the phone Metr app? It’s in the Miscellaneous section.
On my phone I also don’t see the watch as an option from the Play Store app on the phone but I have the app on my watch and use it all the time.
Yes that setting is enabled. If you don’t see the app in the play store than how would I get it on the watch? Like I said the pixel watch 2 doesn’t use the the wear os app. It uses the “watch” app Wich just links you to the play store for all app downloads. So unless I’m missing something I don’t see how else I would get the app on the watch.
I just tried searching the app from the actual watch as well and came up with nothing. There is also no options to add a “tile” for metr
@rpasichnyk Hi, how to make the thing works with Samsung Galaxy Watch6 (running on Wear Os) and its app “Galaxy Wearable”. I can’t get the Metr app on the watch…
I think latest Metr Pro update of may 2024 killed Wear OS support, again…
I can not get Metr installed even on a Fossil GARRETT HR despite it worked with the same smart watch before.
Something strange happened when I was trying to get logs from my Metr Pro CAN. I connected my phone after a ride, and I saw it started syncing two logs (as expected). I then proceeded to the dashboard, where it threw some sort of connection error, but back at the records tab the syncing continued. Eventually syncing finished, and only one log entry appeared. The other log seems forever lost.
Any idea why this might have happened and how to recover the lost log? How to prevent this in the future? I have disabled auto sync, and will be manually syncing from now on…
Hi, I want to make sure that the Metr app remains always active, in the foreground, on the Apple Watch (7). Is this possible? metr app currently goes in background always - thanks for help on how users configure apple watch to have metr app active
I am afraid there is no way to recover the lost log. Please use Manual Sync, it is much more stable.
I have a question about battery %. I have the feeling battery % is link only to the voltage. Like basic feature we find on some kind of RC area (drone). Is it on roadmap to have a battery gauge (%) linked to the battery capacity? Today during foiling, battery indicator was 16% and when I stopped for 2 min discussing with a friend, battery was back to 42%. On the other drone, on all my RC plane, I use the real capacity of the battery to define the % ratio: if my battery is 32AH and I use 16AH, my % battery is ~50%, even If fly 60% cruise throttle. To my opinion it s the best way to define % battery (with a margin for sure, like always). As a Machine Learning developper, I have the feeling this % battery on metr could be really improve. I’m happy to help if needed. Perhaps I have miss something - sorry if this is the case. Regards, Jean.
For all the people who are having trouble getitng the Android Wear Metr app onto their watch, I am wondering if @rpasichnyk can provide the APK and then people can sideload it onto their watch. I believe there are a number of ways to do it. I could grab the APK off my watch but it would make more sense for Roman to provide it.
@rpasichnyk
I’m having some trouble getting my metr pro CAN to work.
It seems to connect to my phone well via Bluetooth and allows for some information to be collected by the metr (VESC hardware and FW) and GPS seems to be working fine, but it doesn’t seem to display any RT data.
It just seems to get stuck in a perpetual state of “reading Go_FOC_DV4s configuration”
Can you please send logs from Metr → Settings → Show Logs to roman@voyagesystems.eu? Thanks!
Hi, i have some trouble connecting to my metr pro. In the beginning it would connect to metr app perfectly fine but struggle to connect to vesc tool app and bug out trying to connect to can or do any setup. So i used vesc tool on windows to redo motor and input setup. Windows works perfectly fine but now metr app and vesc tool app does not connect. Does constant flashing green and blue light mean anything?
Hey, i just got the new remote from the flipsky the VX1, is there a way to somehow connect them both to the vesc so that the receiver is in UART connection?
Thanks
so i was a bit incomprehensible, i ment if you ca connect both, the reciver and the metr pro module
