Measure 10 pins then divide by 10 to be sure
Good tip!
Especially since many measure from the outside edges of the two pins and doing that across ten pins has a much smaller effect on the divided-down value.
thanks fellaas, yeah google fuād how to meaasure properly. and yes great detective work. was on celly, meant to say āwhich jst these areā
Just confirming that this is ok
Will be Both a parallel and series connection
Low power 10s2p
2 bricks in series
i did
these cells are spares and that was from a test weld one which to cold
i checked and no holes
i will not weld on that point again and it really looks fine and i checked the voltage a couple months ago and now and it has not gone down by anymore then any other cell
Really confusing why you wouldnāt just put the groups in a rowā¦
To be fair thatās a good idea
Not sure why I didnāt think of that
Thanks a lot
Has anyone of you ever seen such a anti spark switch? Just pulled this out of my brothers board, never seen it before.
Wild lol thatās a huge fuse
Me thinks itās an old vedder style switch. Only vendor I could recall with them still listed
That soldering makes me want to cry
@JeffyJ just exploded one. Not sure which model, there wasnt much left of it
I did. Iām not saying it was not my fault though. I had it running in conjunctuon with a second built in antispark on a flipsky 6.6 esc. Only cause Iād glued the Volokno switch button in and couldnāt be fucked taking it out. It worked great on all other escs until the flipsky with in built antispark. And it did work for a while on that setup. Esc is dead too so not entirely sure what happened
And it probably burnt as bad as it did because when it failed i thought it was the esc that died. I kept trying to kick push my board but resistance kept getting worse. When i stopped to unplug my phase wires there was smoke pouring out
Thanks guys
So from what Iāve seen I can just bypass the fuse, should be okay.
Did yours come with a heatsink? Because this one didnāt.
My antispark? No heat sink, no.
Does it work?
Flawlessly as far as I can tell. Iām just rebuilding his pack from 10s2p to 10s4p and this was build right into the pack.
