I just got a meaty LTT 15s 120a BMS, it’s got 3x 10awg leads going in and 3x going out, do I need to use all of them? Just using the one on the end would be preferable
There’s a copper bus bar on the inside but there’s 9mm of just PCB, looks about 2mm thick and the traces are 8mm wide
120 amps split between three conductors gives 40 amps each, which is pretty conservative compared to what most esk8 and RC folks use. I’d say you’ll be fine with a single wire.
Would love to see some of you folks more elaborate battery pack designs, ones where you’ve tried to utilise every last space in your enclosure in the pursuit of all that AH goodness.
Oh god its absolutely awful, you do the math and you’re like ‘this will work just fine’ and then you put it all together only to find out that there’s an extra 4mm of width on your battery for no reason at all and the enclosure is tapered at the bottom
Just don’t do it, leave a healthy amount of wiggle room unless you wanna cry for a solid few hours
However when it works its glorious, you feel very accomplished
Its just awful. Don’t do it. I couldn’t even fit an LLT and running a small balancer board atm. Will change to a flexi once they are available again though.
It is, but after discount I think I paid around $20 usd more than what I did from simos.
Hope he can get back rolling again soon, chip shortage doesn’t look promising though.
I like everything about the flexiLite other than the FW update process
