I may actually go and get a second lipo lol, my wires got noticibly warm after about 5 welds. Battery uses 10awg leads which is the problem
Hitting it with a Dremel cutoff wheel to check for sparks is usually another good test, however I once had what I believe was nickel plated steel somehow not spark? Was strange.
If you have a good scale (.01 or .001g) and a good way to make a precise cut (like a guillotine cutter or quality scissors) you should be able to weigh and compare densities. Whatever Chinesium steel alloy used in fake nickel could come fairly close to pure nickel tho…
Ahh, I do have those things.
Looking good!
thats the easy bit
rounded the nickle and waiting for lipo 2 to charge up and then gonna weld
praying for no sparks
No fish paper rings?
i put them on
just after i took those pics
you will see when i put in my welding pics
Okay good you had me scared for a minute lmao
yeah sorry
just easier to put them on when all cells are stacked together
after around 70 welds my electrodes get hot enough that i gotta stop welding
is that normal?
also kweld is so much better then any other welder wooooooooow
looking good?
maybe a tad to hot but overall not bad (one on the bottom left was much to high settings still)
The welder probes get hot pretty quick yeah. Just take some breaks to let them cool down.
(A fan blowing on the probes helps)
Yup kweld is the best welder out there that doesn’t cost a fortune
Those welds look pretty good so far.
Just remember to not weld in the center 3mm of the negative side of the cell.
yeah
thanks a lot
will try to avoid the center
does the centre rule only apply for the negative?
also they survive the pull test very well
nickel rips around the weld leaving remnants there
Yes only the negative side of the cell. That’s where it is internally connected.
Perfect.
thanks a lot man
how come you did circles on the pos then? just easier that way or for a reason
Welds are stronger the further the probes are apart and the circle comes from that
