They’re charging! Cable management for the mains will be some more hot glue into the battery gaps, I measured that beforehand.
Just doing an initial charge before shrinking all the PVC wire tubes around the solder joints, and I still need to add the XLR charging port, which will most likely be to the serial connection wire instead of the battery packs.
My experience with battery packs is probably the same if not less than yours, I’m trying to wrap my head around stuff as well. So my diagrams would probably not be the safest bet.
This type of BMS have I think 2 different self discharge rates. And various models (and with how recently it was made) have different behaviors. The good thing is you can check it with your phone easily. The bad thing is you kind of have to check it once a month or so. With 4 months down I’d put the pack at storage voltage, then disconnect the pack including the balance leads?
The different length nickel is just due to human error and the different widths is because I ran out of the 8mm nickel strips and I had to use the 5mm ones that came included with my spot welder.
Is it a big problem?
Why is the trapezium shape better?
With the way you have it it’s hella lot of work cutting all those strips, and they come out all uneven. And you have basically a line connecting 5 cells. With the trapezoid you will have way way less cutting, more consistent electrical paths, and current sharing will be even. And more metal, so less resistance.
If you have all these different amounts of nickel on each p group, the resistance for the p-groups will vary. If the resistance varies, they will charge and discharge at different rates. Your pack will always be drifting out of balance, and cells will wear at different rates. This effect might be so small as to not matter, or it might be annoyingly large. A lot depends on how the rest of the construction is done (series connections).
