This is a Diy battery?
What BMS?
Sounds like a bad cell/cells maybe idk.
What BMS?
I donât know what BMS iâd have to cut it open. I think i have to do that anyways.
Yeah if you can get to the balance wires you should be able to tell everything with a multimeter.
thatâll be my next move⌠thx
What does the builder say?
Is there any problem with connecting my balance wires to the negative of the next cell, rather than the positive of the cell im balancing?
Reason being I have 3 layers of nickel everywhere except this one spot in every p group, would like to put my balance tab there as long as its all goodâŚ
No problem. Itâs preferred and itâs also how mine is built.
This way youâll have less tabs on the positive side and so less chance for shorts.
Excellent. I shall proceed.
I donât understand how you managed to fit 12s8p in hummie! I could barely fit 12s6p with dual ESCape inside! well done!
He stopped answering my emails after the first problem day one this battery had problems.
Dude, its the best.
Why do you need 2 kCaps?
To have a piece of mind
Longer life, less heat, more current all the good stuff haha
Hey Drone-
Iâm confused on one aspect of this: Is this a different battery than the one you bought from @Psychotiller that had issues, or is it the same one and you sent it to @hyperion1 to be repaired?
Sorry, canât quite remember.
Yes this is the same battery I originally purchased from tiller. He replaced BMS, nickle strips and vented cell. Few days later more problems. I then had hyperion check it out. He replaced the BMS and p group (he sent pics and all) now after a few daysâŚI got the problem I have now. I have the worst luck ever with this battery.
Im just about to order the kSupply and kCap⌠now youâve got me thinking.
Man, I hate to hear this. Hopefully weâll hear something from them, because you deserve better than this.
