When substituents are in the axial position, there tends to be more unfavorable interactions with other axial atoms on the same side. … When substituents are in the equatorial position, they are farther away from each other. This increases the stability of the conformation.
So it’s the BigBen fiberglass enclosure on a Bustin Sportster, so I think that’s about the minimum flex I’m gonna get. Its got pneumatics and I’m light so that’s the least stress a board will ever see. Is that still too risky?
I refuse to fold nickel anymore lol. Prolly not the best to ask for my opinion.
Haha that’s fair, I think it has it’s uses but I’m not 100% sure if this is one of them
I concur…their longitudinal concurrence tendencies can often cancel out axial instabilities.
Mooch and k00k concur!
keep the weld bends on the deck side to minimize issues if you have to do it that way.
Hi, i was thinking of charging my 10s battery (2x5s in series) with imax b6. is it possible to use 8 pin porrt for each of the batteries so i dont have to plug the xt60 and the jst connecor to the charger?https://pl.aliexpress.com/item/32865941375.html?spm=a2g0o.productlist.0.0.1490579510bl0S&algo_pvid=4f1402d3-5cc0-4871-afd5-c538b1516fa5&algo_expid=4f1402d3-5cc0-4871-afd5-c538b1516fa5-10&btsid=0b0a01f816019896556312131e186f&ws_ab_test=searchweb0_0,searchweb201602_,searchweb201603_ i just would like not to open the battery box each time i have to charge, Thanks.
yup
Thanks, so I just use 6pins for balance cables and two for the main power cables?
for 10s there are 6 balance leads and two power leads. so 8 pins total. don’t get cheap and go 7 pin like me. it works but it’s not right
why 7? if charger needs the main voltage reading and the 6 pin connector
I believe if you you are doing a fast charge, it doesn’t go by the balance leads but rather only by the 2 main ones
so there would be no point in using balance leads, just plug in to 10s power supply
Well…I wouldnt recommend not balancing them. LiPo don’t like it when you don’t care for them
kinda like my wife
sure, i would like to charge the battery correctly but im not sure if i should get 7pin for 5s or 8 pin connector
I’d say go for 8 as @iamasalmon recommended. It’s already a 6s +mains. Keeping it that way would mean 8pin.
Thank you for help
@iamasalmon did most of the work, I go off from what I’ve learnt from them
