Do you think you’ll run out anytime soon? I might buy some (though in the probably distant future lol)
I think I have about 19m, that should last a while
Does anyone have p42a laying around with a bit of spare time for me?
I’m trying to calculate a 12s3p pack to see what box I need. Don’t have them in hand yet but I’d like to order the box so I have a safe spot for them as soon as I do.
Edit: calculated with the wrong setup
What layout are you trying to do?
@ZachTetra
Forgot to state that. Its top mounting for the mbs.
So either
layed flat on top of each other in 3 or 4 stacks
Or
Upwards in 2 or 3 rows
If it has any importance, they’re @Skyart 3p packs
For a vertically orientated block you get this
| rows | cols | length | width |
| 3 | 12 | 73.5 | 221.046 |
| 4 | 9 | 94.5 | 166.488 |
| 6 | 6 | 136.5 | 111.93 |
| 8 | 4.5 | 178.5 | 84.651 |
| 9 | 4 | 199.5 | 75.558 |
| 12 | 3 | 262.5 | 57.372 |
@ZachTetra since a 3row/12col is not the same dimensions as a 12row/3col, could you give me an idea of the difference?
it depends if the lines of 12 or the lines of 3 are straight
How much space do you have?
@ZachTetra so if I were to go with something like this
I need to look at 6x6 dimensions plus a bit of extra for the bms?
That block is 126mm * 126mm * 70mm theoretically, is that what you want?
An im2050 or less(would love less)
Because you can fit a 12s4p P42A and a smart BMS in a Pelican R60
Got a pic of that?
Check my black bear thread, playing ow
That’s the case you accused me of making you buy? Do you have a pack built in that case?
Lol yes the one I accused you of making me buy
I haven’t made the battery yet but it’s an easy one, I will be doing the zig zag U
I’m trying to figure out if 12s3p has any chance of fitting in a r40
Internals of
24.99 x 15.54 x 7.34 cm
first set is stagger pattern, second set is square pattern. Basically all of these will work
| rows | cols | length | width | length | width |
| 3 | 12 | 73.5 | 221.046 | 63 | 252 |
| 4 | 9 | 94.5 | 166.488 | 84 | 189 |
| 6 | 6 | 136.5 | 111.93 | 126 | 126 |
| 9 | 4 | 199.5 | 75.558 | 189 | 84 |
