Absolutely. IMO, temperature control is the bare minimum feature to shoot for.
Directly heated tips (Hakko T12, Pace TDS100, TDS200 and WJS100, Weller RT, Metcal, the list goes on) are a major, MAJOR upgrade that should be considered, especially when knockoffs are available at double-digit price points, because not everyone needs a $200+ Pace soldering station for their occasional hobby work.
I donāt think it does because the pcb would probably need a special chip that would make it āsmartā and somewhat progammable, but if it does someone would correct me⦠right ??
Does the battery even get recharged when braking? I want to know if I have to set the regen brake charge to 0 if it isnāt going to be discharging by p-. Iām pretty sure that p- isnāt necessarily needed, but I want to make sure my working bms doesnāt have more voltage due to braking, if the 2nd cells donāt do it.
Hey, Iām going to make a 10s3p pack and Iām worried about LG MJ1 cells performance. I got a good deal on them, but they arenāt as widely used as 30q so I would like to confirm a few things first.
If I understand correctly my 2 motors 15A peak current will take 30A in total. LG MJ1 have 10A max continuous current each. So by having a 3p pack I should be good?
In terms of BMS any 10s 35A BMS should be sufficient? Or can I go lower with the amperage?
Welcome firstly. Second, the bms on that battery is fine since its 30amp continous (stronger than mine if I did one in 3p since theyāre samsung 35E cells). The motor probably gonna be based off on your vesc, so i wouldnāt worry about the motors since that will be based on your foc parameters. So the focus is splitting your batteryās max current to 15A each motors. But do find out your max regen charging for that battery.
Its 1c or 5amps max regen charging. So 2.5amps per esc.
Personally, I would just solder then individually. In that sense, it can be considered as redundancy. So instead of both breaking off, itās just one. Itās also a little less work to just do both individually.
I made some pretty small tabs (I didnāt think ahead) for what people would probably use for one thick wire, so I hope it just doesnāt heat it up so fast the other wire comes undone lol. otherwise im gonna need new wire or Iāll have to redo my tabs
My charger on my euc does the same everytime with the charger plugged in the outlet or not. It always has a zap when plugging into the charge port. But every euc I have owned does this
