Trim your corners!
You can grab the nickel with pliers and roll them to get the nickel off
Will do chief
@YeetMeat But try not to short it out with the body! Had my first sparkles doing that
Is this too much fishpaper and kapton?
My p groups are separated with fish paper like this:
Then I added a layer of fish paper on the sides and the top.
Finally, wrapped everything with single layer of kapton
Is there any concern of overheating? I tried searching and havenât found any cases.
Nah more is better in our case, cells shouldnât generate that much heat or youâll have other problems anyways
Itâs chunky! Thatâs for sure. Looks plenty capable. I would draw a max of 90 from that and expect some sag. 60-75 are more reasonable numbers.
Any reason you decided to discharge through BMS? Iâm sure that 100a cost a bit and itâs big
I would recommend fishpaper between P groups in the future
Itâs actually pretty small and light for a mtb battery pack (just shy of 2,9kg). 135A peak from the cells should be the theoretical limit. The bms is a chunky one bacause the cusomer wanted a super safe pack.
And there is fishpaper between the P-groups ofc
Thatâs the mfg rating. 30 amps per cell max if youâre not monitoring temps
Itâs an LLT bms, dual thermistors that tell the bms to cut if heat is too high.
I had a thermistor drop out of between 2 pgroups and landed very close to a MOSFET on the esc. Result:
âItâs a birdâŚitâs a planeâŚno itâs a cutoutâ
Hey you cool cats and kittens. Made some more progress. Re-flowed that main terminal without issue
Wired the charge leads and bms although due to my inexperience laying out the battery there are several balance leads crossing. Once Iâve confirmed that everything is wired correctly, Iâll secure the wires and insulate any crossovers w fish to solve that issue.
And now, the moment of truth. Iâve quadruple-checked my wiring and Iâm confident everything is correct. Any tips before I attempt to charge (aside from taking the pack outside and having the fire dept on standby)?
Iâm assuming that you checked polarity and all the voltages with your multimeter already?
I have confirmed polarity and voltages at the main terminals. Iâve seen some builders confirm voltages from main neg and progressively check each p group which I havenât done beyond the first few. I got the correct voltage of 37.x when I checked the mains as I have the cells at nominal.
I usually check all the way down, but before I plug in the balance connector, it sounds like youâre good to go to me lol
Hmmm⌠If youâve wired the bms incorrectly, can simply plugging the connector in cause a short?
Yep lol
If your balance leads were in the wrong order youâd be out a BMS pretty much, usually a resistor pops
Fack⌠I have a few spares but that wouldâve been a bummer. Glad I took my sweet time to make sure it was wired right
Good job haha I always measure my balance connector like three times because I blew up the very first one I did a few years ago by doing it wrong and had to wait a month
Main pos terminal and then each pin starting at the last cell?
Um well I usually try to measure from the lowest voltage (cell 1) and go up (cell x) to make sure theyâre going the right direction, I donât remember off the top of my head if itâs pos or neg lol whatever works really
