Maybe I’ll get in touch w Jared and get the name of the bms… Would make me more comfortable having a wiring diagram from the vendor themselves.
Anyway, these are the pics of the original pack not the one I’m buikding if that wasnt clear. In pic 1 you can see the main neg terminal connection (12 awg black), balance lead 1 going into the 1st slot of the jst (white wire) and B- (black wire) soldered to the board into the B- trace.
In pics 4 and 5 you can see the main pos terminal (12awg red) balance lead 10 going from cell 10 neg terminal (white wire, second from the right) into the second last jst slot and another white wire (further to the right; what I had labelled B+) going from main pos terminal into the 11th jst socket.
Ah, I see.
yeah, the first wire is not always used, depending on the BMS. usually if it is there it is labeled B0, which would make your B2 -> B1, and so forth.
Haha soon my friends, in the coming months there will be enough for everyone, so far at least @whaddys, @kevingraehl, and I have large orders coming in
If someone is in emergency need of some 30x0.2mm stuff, I might be able to help with that. I just received 5 meters and I am not planning to use it for now. Already got my pack assembled with nickel from @ZachTetra.
Fellas, I’m having a little trouble sourcing shrink wrap for my pack. It’s 9 cells across and single stack so I think 190-200mm is about right but correct me if I’m wrong. Any one got a North American vendor? I really don’t wanna wait for the slow boat. Tia.
