What kind of battery? Perhaps more amps will keep the pulse time and the heat down.
I used a 3s3p SPIM08 (on sale now at BCH for $40 shipped) with fantastic results on .2mm thick nickel on both the Malectrics and the Kweld.
isn’t puffy about how hard you use it. shorting it to spot weld does seem harsh.
what would increase it’s longevity in a spot welding application. does more time between welds help? generally keeping it at higher SoC all the time? ( no idea, just guessing / wondering )
I have the 5000 mah 60c that the kweld site recommended too. I’m wondering how long it’ll last. pretty sure everyone gets a better battery. or another in parallel.
It’s harsh. like battery torture harsh.
I had a smaller battery for my first and it did NOT like the longer pulses required for thicker nickel. everything would heat up and shit wouldn’t stick. Had to step up my game, welds all day now.
Your expectations of that specific lipo in that specific application are probably a bit generous. You need either more C-rating, or more capacity, or (preferably) both.
And yes, you destroyed that cell. That distinctive fruity odor is the death gurgle of a lithium battery.
Hey battery experts
My friend’s Meepo battery is dying and he’ll need to replace it
Would a 10S3p 21700 Molicel be ok with an Hobbywing ESC and Hubs, or do he need to build the battery with the same cells? (In his Classic V2 it’s 35E If I remember well)
You just need to satisfy the amperage requirement of the ESC as the minimum possible cell output. I believe that number is 32A for their lingyi ESC but hard to be absolutly sure of that.
