That wow at the end killed me.
You donāt have to charge to full to build the pack. Could do them all at 3.7.
Cells will bleed back a bit. Then again, a 0.1V change is nothing and could be beyond the true accuracy of the voltmeter you have anyway
Vvvvverrrrry nice looking!
you got a link to that tape you use?
Yes those are 9p staggered with 5 cells on the bottom and 4 on top then itās the same thing by flipped next to it
How many joules you running?
33.3 on 1.5mm nickel
Maybe 30? I found that the negative ends need a bit more powerā¦so Iād do 30J for positive and 35J for negative maybe? Itās all close enough that it doesnāt really matter
totally dude, I noticed this as well. Iāve started changing the J just slightly between neg and pos sides. Iām getting betterāthis whole art really is just practice. Iām glad I have these salvaged cells and thin nickel to practice with. Perhaps Iāll give away this 13s practice battery when Iām doneā¦
IF IT BLOWS UP HEY IT WAS FREE
Turn up the current untill you see heat marks, then dial it a bit back more heat is better then less when welding
Haha, I have a 6s3p of fake 30Q cells with a broken BMS if anyone wants that too
from my read, thatās the creator of the kweld saying. comparing joules reading between setups isnāt very useful. because it can be inconsistent between setups. it is useful for consistency though.
it does seem like people compare joules a lot though.
Itās the easiest thing to do, but thatās why I wanted to know the set up he was using, now itās a relative measurement
I"m hands up for some dead cells for practice welds. and any advice on practice welding.
and any extra 2mm nickel for the same.
also looking for wide 2mm nickel 25mm or 30mm for my p42a builds upcoming. probably getting that from @iamasalmon when his shipment comes. but putting it out there.
My joules are bigger than your joules
Big joule energy?
Damn, you got me
Hi guys back again with a spot welding safety question.
Whatās a good way of welding leads to this positive terminal?
I was thinking of doing this, but I realized if I try to weld the middle strip between cells it could go all the way through to the batter negative:
Any ideas? I only have 8x0.15mm strips.
