That would actually make way more sense, especially with the cheaper chinese packs that use nickel for the series connections.
I really think we need to come up with a standardized way of testing fully built batteries, as battery performance is typically the bottleneck for most builds and battery performance can vary greatly depending on grade of cells, and how it was constructed.
Only issue is accurate IR tester’s are fuckin pricey or absolute garbage.
What excess bits of a cell?
If you are referring to remains of old spot welds then no as long as you are careful.
Almost any Dremel type grinding stone will do the job.
From what I understand lithium ion batteries are a bitch to get accurate IR readings on. I do have a tester but even on a single 18650 results vary a lot, this becomes even more of an issue when you are trying to test entire packs at once instead of just a few cells at a time.
Even further there’s a bit of debate coming out of how much IR resistance actually tells you these days with lithium ion and all the extra additives that slightly alter the chemistry can make the cells have wildly different IR’s depending on the testing method (DC load vs AC frequency).
It seems the most accurate method for getting the full picture of L-ion cell health/performance is to test the electrochemical dynamic response of the cells which will measure ion flow by testing across a wide range of AC frequencies. Essentially telling you everything you need to know in terms of cell health and performance, this is really the only way to test a full pack reliably and be able to compare to to any other pack around the world easily.
I can’t have any luck, can I?
Just found out the Turnigy nano-tech Lipo pack I got for my k-weld has a broken cell.
The pack can’t supply any current at all. Cell #2 just drops all the volts when any load is applied.
Hi All,
First time Unity user, installed on my new build. Having issue with power staying on, momentarily stayed on then shut-off. The power on sequence is halo angel switch >> Unity switch.
I can buy a sunkko with Amazon prime protection (refund on return, no questions asked)
I like the kweld. My friend uses one and it works well. But i dont want lipo, so no kweld for me
It can be powered with supercapacitors and a power supply running on mains
If you can get a sunkko like that thats really good, but i doubt that it will be able to make welds better than kweld, and the electrodes for it you can make easy at home
I tried only one sunkko, it was crap and the company has fallen in my eyes a lot so Im biased a little.
If your getting a sunkko get one where you can plug in some kind of electrodes you hold in hand
Of course, the BMS is the first link in the chain.
Unless you turn on the BMS , no power goes to the Unity.
So you first need to turn on the BMS (a latching switch is required) then the Unity using it’s own momentary switch.
If you short the BMS switch then it will always be on and you can use the Unity switch only.
