Saw a review on their site in german that I think translated to “failed to weld 0.2mm nickel”, but I’ll take your word for it.
I’d say turnigy silicone wire form HobbyKing. That’s what I use.
Kweld is basically just a switch, a power source can make it great or shit, same as the boss level/any other welder
yes pure nickel
Welcome!
kWeld is definitely the more robust and capable welder. Hard to kill and very powerful. Boss is smaller (1/3 size) and more multifunction (soldering iron). There’s a mini boss if you’re looking for portable.
Copper is better but not really practical to spotweld, and copper film of the thickness we can attempt to weld is physically flimsy. 0.2mm nickel seems like the practical limit for the normal spotwelding process. Going further requires some changes to the process. Get the widest strip you can fit. If I were you I’d look at 25mm or so wide, folded over onto the pcb.
scissors work, at least for a little while. I use tin snips, but they leave kind of a serrated edge.
I go around with smooth jaw flat pliers. Like these
Fishpaper for abrasion resistance, kapton for heat resistance but not abrasion, and when you need it to be thin.
Yes you should worry. Unless you’ve potted every single piece of electronics.
But you could design your stuff to not let electrical components get wet if a bit of water gets into your enclosure (because sooner or later water will get in).
ebay and aliexpress for silicone wire. Look for “tinned copper”, “flexible”, “many fine strands” (look at specific strand counts, compare listings. there’s a standard high strand count for each awg). Other than that the wires are pretty damn similar across sellers. It’s always a pain to search for the well priced ones.
Fuses look at digikey, mouser, arrow. Don’t buy generic fuses.
Charge port, there are so many choices…
Thank you for answering so many of my questions!
Will look into getting wide nickel strips for 21700’s lol
I have a welder question. What cheap but functional welder would be suggested to me? My criterias are simple.
1)Must not work on lipo.
2)Needs to work out of the box (least building possible)
3)Must not work on lipo
4)No need to be portable
5)Must not work on lipo
6)No car batteries
And most importantly,
7) MUST NOT WORK ON LIPO
any suggestion?
Ps: I use Canadian rupees (worth shit)
A car battery with nails and jumper cables
Defies number 2)no tinkering
Whatcha mean? There are no settings to play with
It either makes a pack or burns down your house, no inbetweens
@ZachTetra just for you
Well, the only thing that I can think of that fits are the sunkko spot welders.
But I don’t have any experience with them. I just know they are out there.
You must need some kind of power source.
How about you take some copper nails and bend them at an angle. Then put them in your outlet and then you’re ready to weld! Just turn the outlet on/off really quick
like reaaaallly quick.
Remember to not touch both nails at the same time when you are welding!
Good luck!
Edit: you could also make one of those welders with a microwave transformer. Needs a lot of building though…
It’s possible to build a spot welder from a microwave transformer but honestly spot welders kinda suck on 120v. To get reliable welds I’d say a Lipo or battery spot welder are a must.
Or you’re using industrial grade equipment on high voltage lines.
Tl:Dr buy a boss and a lipo it’s worth every penny!
I have a cheap sunko spotwelder it worked right out of the box and so far has had 0 issues. But I’ve only made one 10s 4p with it so don’t know the longevity. I’m on 240volt power think I remember something about them not being as good on 110 volts. which do you have in canada?
Guess this just means I won’t be welding anytime soon.
I dont want lipos inside my house. Too many bad stories have made that clear in my head
I have access to both. It’s just a breaker switcheroo (I made the electrician wire everything for 220/240v but breakers are set for 110)
Well sunko works 4 me so far on 240 i had to put in some effort to rip of the test welds with pliers . I think it was Aus$160 on ebay so probably about us$90
edit us$110 just converted it
Which comes to 145$cdn
