still, you can leave all those bms, connect them in parallel so they are 2sxp, use step down to 1s for usb output and you can charge your phone
If I got you right, you would like to use those bms for 12s pack but with 6 x 2s charge only bms? I am thinking hard about it but I am not sure if it would work. I guess it should?
I feel that balance current is a topic not properly explored when folks discuss BMSâs on this forum.
Or rather, speaking for myself, I dont know enough about balance current and comparing BMSâs, and my reading on this forum has not shed a lot of light on it.
It seems like since most of us are using BMSâs as balance chargers only, balance current should be one of the main factors considered when looking at different BMS options. Is there a thread about balance current and comparing different BMSâs?
Just use 25mm everywhere you can simpler easier and better in the end
No Problem!!! thanks⌠Iâm not dissuaded⌠I normally charge to 4.0v~4.1v 12s2 or 3p with quality cells and balance charge once a week or so!!!
EDIT:
and Iâm not above looking into moving the entire charging balancing operation off the board and out of the enclosure.
I liked your way so I copied and did similar.
Left some extra nickel that I drilled a hole in, did a knot with the wire, soldered and then put a shrink tube on it.
You still got these @BluPenguin ? Need one for sure, maybe dos⌠Youâre in OC like me if I recall what Dr Mike told me last time I was with him right? LMK whatâs good and if you are on OC lets ride soon too!
Where did you find glands so small and whatâs the product code if you donât mind?
Iâm looking everywhere but hardware stores donât really do under 20mm
Yup, still got a bunch of em!
I think you are talking about these: #Aliexpress US $1.24 6%OFF | 10pcs IP68 PG7 for 3-6.5mm PG9 PG11 PG13.5 PG16 PG19 Wire Cable CE White Black Waterproof Nylon Plastic Cable Gland Connector
I got PG7 black
Got them (off amazon though). Thanks for the name!
So excited to move away from compression packs and up to the big leagues
Anyone have a source for 15mm or 30mm wide pure nickel? Looking for 0.2mm or thicker if possible. Bonus points if I can get it shipped to the US in less than a month
Fogstar was shipping some idk if they are operational.
They dont ship to the US
No you email them and they will ship some to you @BenF is not really on the forum anymore so the offer might not stand.
Congrats! You going to love that welder! What are you going to power your with?
My carâs battery
25mm? thatâs too much
My mind is blown. you just saved me hours.
To bad I pissed away more time figuring it out than if I would have just sat my ass in a chair and cut away (I presume we are talking about the nickel corners).
âŚfor the community!
They still discount stuff if you mention this forum. Not sure about nickel though
