The battery builders club
What is your problem?
There are good mini options for 10s charge only. If you look for bestech or similar you can even custom your cut off voltage.
12s charge only I do not know anything smaller than the d140 or similar, but there are smaller versions which cut off only but do not balance. Probably the same good like a simple balance bms… with 80-100mA you anyway do not balance much out.
Deal. This year everybody only gives charge only BMS to each other.
lmao. You’re optimistic.
I have a question, this seems sketch to me - I want to send it but I wanted to check in with the more experienced guys and see what was good
So I have copper “tape” strips. It has adhesive on the bottom. Are these copper tape strips made for stuff like this? Can I get lazy and use copper tape strips to make my battery pack provided I provide the rigidity to make these things last?
Or should I stop being lazy and just bust out the soldering iron
I’ve only made small little 3s battery packs for my flying wings, this is my first “big” 10s2p pack.
I’m not sure it’s conductive on the bottom, and they can’t carry more than an amp before they get HOT, and they will probably rip anyways. You really should use a spot welder
You can solder the cells but it’s not good for them, make sure your iron is really hot and you rough up the surfaces first (Dremel or sand paper)
I’ve had success with a soldering iron but spot welder is definitely the one to use.
Thanks man I’ll find some wires and do this the proper way
The tape is not conductive on the sticky side… Even so, way too thin. Weld or solder if you dare.
I’d say you may be able to get away with it if you were building a power bank to charge your phone…
But for an esk8 pack? Absolutely fucking not.
Not true, the stuff is conductive. Example:
https://www.stewmac.com/Pickups_and_Electronics/Shielding/Conductive_Copper_Tape.html
But it’s not for high current applications. I gotta say, don’t pronounce things as fact without doing at least a quick check. @ohitstarik adhesive copper tape/sheeet is not for this application.
yeah I had tested it with my multimeter and it’s conductive. not that big of a deal though, maybe the ones they used weren’t conductive. :man_shrugging:
The roll I tried for something from a long time ago was not… I had to fold it over to make something work… but cool they come in conductive versions too :woman_shrugging:t3:
Apologies, should have held that attitude back.
No it’s fine, I should’ve looked. I just remember using copper tape like that that was used for shielding noise for guitars or something and it was just backed by like 3M tape…
40ts anyone?
I have some copper tape that I use to sometimes quite down FET electrical noise…blah…blah… I just checked mine… mine is not electrically conductive what-so-ever…
you selling?
I may be wanting!
How much each if I get 24? 48?
hahahahaha
same hah
jc lol they’re not for sale #stormcore
Anyone has some D140 12s for sale in EU?
kweld containment unit
