I would bet that something went wrong in bms during balance wires connecting phase. Never leave balance plug in bms when doing that.
You are 100% sure that balance wires are in right order? Did you check that with multimeter on plug?
unfortunetely i didnt, i know thats dumb, i connected them like on the scheme i send a picture earlier
You can build one with a DPS and a balance bleed board. Like that you can charge anything from 1s to 16s
i have checked the balance wires and all af them ale wired properly
Yeah, theyāll screw into the existing terminals. Or more accurately, the existing screws will tighten the ring terminals against the tabs
I mean if the screws go into the side of the NESE module youāll have to carve out pockets in the sides of the deck for the screw heads and tabs
They go on top and bottom, not the side. The green nese is an example of one completely assembled. For the horizontal white NESE, Iām thinking of breaking it down into 1S4P to get around routing the deck. Still not sure what to do about balance wires though
Yeah balance wires kinds suckā¦Iād say solder the balance wires to the nickle and drill a small hole that pops out the top of the modules for that wire to come out of
The thing is Iām not sure there is enough space on top with the current NESE. In talks with Agniusm right now on potentially thinner NESE. Itāll just take a while though
Alternatively, any dangers of balance wires being crushed? If not, Iāll just run them on top and call it a day
How much space is between the top of the NESE and the bottom of the lid?
The enclosure is suppose to be 23.5mm. The NESE are suppose to be 22 +/- 1 mm. So itās pretty close
how to check if the bms is dead or not?
Well, it gives only some small voltage out? 2.6v?
Similar thing happened to me few times with few bms, but I knew I have shorted them. Just small voltage output and unusable bms. Buy new bms, at least charge only are nit expensive
thats true, i have just ordered one frome ebay, thanks for help
It wasnāt my charger. Believe me, I would not have sold it if I owned it.
@iamasalmon @privacydoctor thanks dudes, but I absolutely cannot be fucked with that adventure. Happy to buy a good product rather than fuck around.
At this price point I havenāt seen an other 6-12s balance charger that would be comparable.
The Icharger are probably better but also close to be the double in price.
Excellent. I knew I could count on you.
I did have a good google last night but there isnāt a hell of a lot of information/opinion out there, especially regarding the up1200ac.
But after my limited use with it, my gut tells me itās good.
Cheaper option could be dual 6s charger and mid pack loop key. Charge each half pack at the same time. Maybe not ideal - not the same as a dedicated 12s charger, but cheaper. I have a t240duo which is about $100. NZ$ 92.20 12ļ¼
Off | HTRC T240 DUO RC Charger AC 150W DC 240W Touch Screen Dual Channel Balance Discharger For RC Models Toys Lipo Battery
Cheers bro, but it doesnāt need to be cheap! The up1200ac will do 2 x 12s (or less) at a time, definitely donāt wanna be fucking around with split packs.
